Visitor miantang
Use /dev/mem to visit physical address
I'm using ZCU102 board and run Petalinux.  I'm trying to read/write registers in FPGA through /dev/mem. The registers address list below:
0xA0041010
0xA0041014
0xA0041018
0xA004101C
0xA0041020
The issue is I can read the data from register which is 8-byte address aligned, such as 0xA0041010, 0xA0040108, and encounter segmentation fault when reading from 0xA0041014 and 0xA004101C. Is it because of 64-bit system? How can I fix this issue?
Thanks a lot.
Visitor miantang
Re: Use /dev/mem to visit physical address
I fixed it on my own. When call mmap, I use void pointer which is 64 bits. To use integer pointer with mmap function, I can visit 4-byte aligned register.
Visitor miantang
I use the mmap to trans physical to virtual address, but I find all register value read are zeros. Do you know reasons about this? ty
