VGA problem on the linux2.6
  The Linux 2.6.24 kernel's Xilinx Framebuffer driver and/or the Xilinx   PLB TFT Controller IP block (plb_tft_cntlr_ref_v1_00_d) does not appear to centre the display on a VGA screen properly(vertically offset).
  Why ,this happen?
  regards
Hi , for 4 days ,i corrected the ip 's bug . Thanks for your help . The solution is here http://www.openhard.org/myspace/blog/show_155462.html
Message Edited by snakke on 08-31-2008 08:57 AM
Historian
Historian
snakke wrote:
  Why ,this happen?
  regards
Vertical sync is not correct?
Wrong number of lines in the display?
-a
Yes,Vertical sync is not correct. How to slove this problem ? thanks
Historian
Historian
If it's a bug in the Xilinx core, open a web case.
-a
Thanks for letting us know your solution.
