Video capture in Petalinux on Zybo
I have a Digilent Zybo z7-20 board and I took the Linux base vivado project and compiled the petalinux from Digilent's GitHub . The os is working fine.
https://github.com/Digilent/Zybo-Z7-20-base-linux
https://github.com/Digilent/Petalinux-Zybo-Z7-20
I observed a dvi2rgb block which terminates in video memory access and also, in petalinux repo, it's specified that there is a hdmi in via uio.
My question is: how can I get a picture from hdmi via user space io?
Thank you!Merry Christmas!
Mentor
Mentor
Re: Video capture in Petalinux on Zybo
Hi @borsec
Would you get video image via mmap in Linux application ?
Best regards,
Yeah, mmap would work. To be honest,  I want a simple example which work.  Then,  I could change my code to integrate it into my app.
Thank you for your response!
