What version of petalinux should I use in Vivado 2017.3?
I want to use Vivado 2017.3 but there is no petalinux version 2017.3.
What version of petalinux should I use in Vivado 2017.3 and SDK 2017.3?
Thank you.
You have to wait till petalinux 2017.3 release. Xilinx releases vivado 2 weeks ahead of petalinux
Alternative, you can validate your design using non-petalinux or open source flow. If you can see for example, uboot or linux, you can see 2017.3 tag
Best Regards
Shabbir
Thank you for your information:)
