When unable to read file uImage, what should I modify in the uboot?
Hi, everybody. when I made boot files for my customized  zynq board, the uart output something like this:
I think it maybe that I set the wrong parameters when I made the uboot.elf, so the booting cannot get into uImage.But I don't konw which files should i modify in the "u-boot-xlnx", I just modify zynq-common.h and make zynq_zed_defconfig, because my board like zed, but it's not zed, so what else files should i modify?
Thanks for reply!
Re: When unable to read file uImage, what should I modify in the uboot?
I modified the UIMAGE_LOADADDR when I compiled the xilinx-linux-kernel.Ensure the ADDR is the same as which in uboot/include/configs/zynq_common.h
Hi 1028271706@qq.com,
Several questions:
- Is it a custom board based on Zynq ?
- Ext 4 file system is enable in your u-boot configuration ?
- File system is setup on the eMMC ?
Cheers,
Trigger
Hi trigger,
Firstly, thanks for your reply.
I'm sure that my board is based on zynq, and i set the sdboot in zynq_common.h below:
"sdboot=if mmcinfo; then " \
"run uenvboot; " \
"echo Copying Linux from SD to RAM...RFS in ext4 && " \
"load mmc 0 ${kernel_load_address} ${kernel_image} && " \
"load mmc 0 ${devicetree_load_address} ${devicetree_image} && " \
"bootm ${kernel_load_address} - ${devicetree_load_address}; " \
As for " File system is setup on the eMMC", I burnned my file system in the Partition-2 of my sd card which is the type of ext4.
Maybe you can try to use this command to set the correct partition:
U-Boot# mmc part
U-Boot # mmc dev 0 U-Boot # mmc rescan U-Boot # mmc dev 1
Cheers,
Trigger
When I burned the pynq linux system to the TF card, it make a patitioning automatically, Partition-1:Type: fat32、partition-2:Type: ext4.
Looks like it is looking at the wrong place for the boot files or it won't see the device.
look at <u-boot>/arch/arm/dts/xxxx.dts  for your zynq_zed device tree file.
and check for these entries:
     aliases {
                mmc0 = &sdhci0;
&sdhci0 {
    u-boot,dm-pre-reloc;
    status = "okay";
&sdhci1 {
status = "okay";
inside your u-boot config file there should be a link to this dts file
in the u-boot root folder do:
nano .config
..and check for macro: CONFIG_DEFAULT_DEVICE_TREE="YourBoardhere"  ( without the .dts extension )
thanks deville, I worked out it.
