Visitor divcesar
Writes to memory mapped regions are too slow
Hi there,
I am using the following scheme to allocate a memory region to enable communication between the FPGA and an Linux application.
A portion of kernel driver:
		vma->vm_page_prot = pgprot_noncached(vma->vm_page_prot);
		vma->vm_flags |= VM_IO | VM_PFNMAP | VM_DONTEXPAND | VM_DONTDUMP | VM_LOCKED;
		result = io_remap_pfn_range(vma,
									vma->vm_start,
									MagicDriver_userAddr >> PAGE_SHIFT,
									MagicDriver_userLength,
									vma->vm_page_prot);
The portion of the application:
    RegistersDriverFD = open(RegistersDriverPath, O_RDWR | O_SYNC);
    assert(RegistersDriverFD != -1);
    Registers_VirtualAddress = (uint8_t*) mmap(0, SIZE_OF_REGISTER_AREA, PROT_READ | PROT_WRITE, MAP_SHARED | MAP_LOCKED, RegistersDriverFD, 0);
and then I use the Registers_VirtualAddress pointer to read and write to that region.
The problem is: the writes to that region are taking too long to appear to the FPGA. I need to insert some delays in between writes to act like memory barriers.
Any ideas what might be the problem?
Visitor divcesar
Re: Writes to memory mapped regions are too slow
bump
