jamead
X server crashes with ZCU104 board and Petalinux 2019.1
Maybe I missed a necessary package when doing petalinux-config -c rootfs?
Boot messages below
X.Org X Server 1.20.1
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-20-generic x86_64
Current Operating System: Linux zcu104 4.19.0-xilinx-v2019.1 #1 SMP Fri Jun 5 21:16:49 UTC 2020 aarch64
Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
Build Date: 11 June 2020 01:42:42AM
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 11 21:10:48 2020
exportfs: can't open /etc/exports for reading
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
Starting internet superserver: xinetd.
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Starting watchdog daemon...done
Starting tcf-agent: The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Unsupported high keycode 372 for name <I372> ignored
> X11 cannot support keycodes above 255.
> This warning only shows for the first high keycode.
Errors from xkbcomp are not fatal to the X server
D-BUS per-session daemon address is: unix:abstract=/tmp/dbus-lnIbXo8e6A,guid=9f8f1dfef390cdb28baf06925ee29dd9
/etc/X11/Xsession.d/90XWindowManager.sh: line 6: /usr/bin/x-window-manager: No such file or directory
xinit: connection to X server lost
waiting for X server to shut down Xorg: ../../xorg-server-1.20.1/include/privates.h:121: dixGetPrivateAddr: Assertion `key->initialized' failed.
(EE)
(EE) Backtrace:
(EE) 0: /usr/bin/Xorg (xorg_backtrace+0x5c) [0x559501ae3c]
(EE) 1: /usr/bin/Xorg (0x5594e8f000+0x18fc18) [0x559501ec18]
(EE) 2: linux-vdso.so.1 (__kernel_rt_sigreturn+0x0) [0x7fb466966c]
(EE) 3: /lib/libc.so.6 (gsignal+0x98) [0x7fb4015090]
(EE) 4: /lib/libc.so.6 (abort+0xfc) [0x7fb4003894]
(EE) 5: /lib/libc.so.6 (0x7fb3fe3000+0x2baa4) [0x7fb400eaa4]
(EE) 6: /lib/libc.so.6 (__assert_perror_fail+0x0) [0x7fb400eb10]
(EE) 7: /usr/lib/xorg/modules/libexa.so (0x7fb3e38000+0x6710) [0x7fb3e3e710]
(EE) 8: /usr/lib/xorg/modules/libexa.so (0x7fb3e38000+0x6c74) [0x7fb3e3ec74]
(EE) 9: /usr/bin/Xorg (0x5594e8f000+0x11bfb8) [0x5594faafb8]
(EE) 10: /usr/lib/xorg/modules/drivers/armsoc_drv.so (0x7fb3e5f000+0xb284) [0x7fb3e6a284]
(EE) 11: /usr/bin/Xorg (0x5594e8f000+0xe12b0) [0x5594f702b0]
(EE) 12: /usr/bin/Xorg (0x5594e8f000+0x115c7c) [0x5594fa4c7c]
(EE) 13: /usr/bin/Xorg (0x5594e8f000+0x61d64) [0x5594ef0d64]
(EE) 14: /lib/libc.so.6 (__libc_start_main+0xe4) [0x7fb4003ce4]
(EE) 15: /usr/bin/Xorg (0x5594e8f000+0x4b890) [0x5594eda890]
(EE)
(EE)
Fatal server error:
(EE) Caught signal 6 (Aborted). Server aborting
(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
OK
PetaLinux 2019.1 zcu104 /dev/ttyPS0
zcu104 login:
jamead
Needed to add the matchbox packagegroup.  Now it works
jamead
cold_er
Thanks for the update, just helped me a lot!
