05-18-2018 03:11 PM - edited 05-18-2018 04:47 PM
- IP, Version: AXI JTAG, 1.0
- Vivado, SDK, Petalinux: 2017.4
- Device: Zynq-7000
hello,
I am trying to recreate XAPP1251. It is made with Vivado design tools 2014.3.1. It is a reference design for XVCServer using JTAG over ethernet.
Following chapter "Connect Hardware", step 4 I am running the application on the target with the following message:
xvcmod login: root Password: root@xvcmod:~# xvcServer & [1] 1276 MMAP Failed
Test case
(1) the periferal is listed as /dev/ui0
(2) the contents of /sys/class/uio/ui0/maps/map0/ are correct (address, size, offset)
(3) stepping through the code in SDK:
fd_uio = open("/dev/uio0", O_RDWR ); if (fd_uio < 1) { fprintf(stderr,"Failed to Open UIO Device\n"); return -1; } s = socket(AF_INET, SOCK_STREAM, 0); if (s < 0) { perror("socket"); return 1; } volatile jtag_t* ptr = (volatile jtag_t*) mmap(NULL, MAP_SIZE, PROT_READ | PROT_WRITE, MAP_SHARED, fd_uio, 0); if (ptr == MAP_FAILED) fprintf(stderr, "MMAP Failed\n"); close(fd_uio);
I am able to open uio0 successfully and creating a socket. It fails to mmap fd_uio.
jtag_t is defined as:
typedef struct { uint32_t length_offset; uint32_t tms_offset; uint32_t tdi_offset; uint32_t tdo_offset; uint32_t ctrl_offset; } jtag_t;
It's fields are not getting assigned any values after calling mmap().
Can someone give me further hints on solving this issue, thank you.
05-20-2018 02:50 AM
05-18-2018 04:38 PM
Hi, your message from your first printout suggests that the open call is failing, not the mmap?
05-18-2018 04:46 PM - edited 05-18-2018 04:50 PM
Uh, yes, I am sorry,
That first printout is outdated, I solved that problem (copy and pasted the wrong text from my document). I edited my question.
05-18-2018 06:06 PM - edited 05-19-2018 04:35 AM
Hmmm, I don't have any additional ideas. Have you looked at errno?
Edit: as a (probably not very useful) piece of information:
Using Vivado/Petalinux 2017.2 I was able to get a virtual cable server to work in a system that sounds very similar to what you have, except for the problem discussed and solved here: socket problem
I am showing below the kernel configuration and the contents of the sysfs entries, in case that is useful to you.
root@yugevu2:~# zcat /proc/config.gz | grep -i UIO CONFIG_UIO=y # CONFIG_UIO_CIF is not set CONFIG_UIO_PDRV_GENIRQ=y CONFIG_UIO_DMEM_GENIRQ=y # CONFIG_UIO_AEC is not set # CONFIG_UIO_SERCOS3 is not set # CONFIG_UIO_PCI_GENERIC is not set # CONFIG_UIO_NETX is not set # CONFIG_UIO_PRUSS is not set # CONFIG_UIO_MF624 is not set CONFIG_UIO_XILINX_APM=y root@yugevu2:~# ls /sys/class/uio/uio0/maps/map0/ addr name offset size root@yugevu2:~# cat /sys/class/uio/uio0/maps/map0/* 0x40050000 /amba_pl/axi_jtag_v1_0@40050000 0x0 0x00010000
In my notes from that I found that the following two things were needed beyond what's in the XAPP1251, both in the device tree, due to kernel changes in the UIO driver. The first passes a choice to the UIO driver, the second is needed for mapping the AXI jtag to the kernel. However, I think in my case these were needed to get /dev/uio0 to be created _at all_ so this is probably not of use to you.
/{ chosen { bootargs = "console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait uio_pdrv_genirq.of_id=\"generic-uio\""; }; }; // virtual cable &axi_jtag { compatible = "generic-uio"; };
05-20-2018 02:50 AM
