xshengshe
XC7Z100, Dual Marvell 88e1512 PHY Ethernet, One MDIO, eth1 can't be found
devicetree is :
&gem0 {
status = "okay";
local-mac-address = [00 0a 35 00 00 00];
phy-handle = <&ethernet_phy0>;
ethernet_phy0: ethernet-phy@0 {
reg = <0>;
ethernet_phy1: ethernet-phy@1 {
reg = <1>;
&gem1 {
status = "okay";
local-mac-address = [00 0a 35 00 00 01];
phy-handle = <&ethernet_phy1>;
xshengshe
I have solved it, the devicetree is is right. Just a little problem of hardware.
xshengshe
