XCU102 XAPP1305 ps_emio_eth_1g 'Card did not respond to voltage select!'
On the XCU102 development board I am trying to get Ethernet example designs working from XAP1305. I have copied the files in ready-to-test\Linux\ps_ethernet_1g on to an SD card and that boots Linux fine. When I do the same with the files in ready-to-test\Linux\ps_emio_eth_1g the first stage boot loader complains that the MMC 'Card did not respond to voltage select!'. I get the same result with images from the PetaLinux environment. In 2018.1 there is a pre-built image that boots fine. In 2017.1 when I follow the instructions in http://www.wiki.xilinx.com/PS+and+PL+based+Ethernet+in+Zynq+MPSoC I get the same error.
Steve.
