love23by223
XCZU3 Gem causes the system to hang
kernel version : 4.9
System hangs while using the network and operating the SD card at the same time
love23by223
devicetree
zynqmp.dtsi
gem3: ethernet@ff0e0000 {
compatible = "cdns,zynqmp-gem";
status = "disabled";
interrupt-parent = <&gic>;
interrupts = <0 63 4>, <0 63 4>;
reg = <0x0 0xff0e0000 0x1000>;
clock-names = "pclk", "hclk", "tx_clk";
#address-cells = <1>;
#size-cells = <0>;
#stream-id-cells = <1>;
iommus = <&smmu 0x877>;
power-domains = <&pd_eth3>;
zynqmp-zcu102.dts
&gem3 {
status = "okay";
local-mac-address = [00 0a 35 00 02 90];
phy-handle = <&phy5>;
phy-mode = "rgmii-id";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gem3_default>;
phy5:phy@0x5{
reg = <0x5>;
ti,rx-internal-delay = <0x8>;
ti,tx-internal-delay = <0xa>;
ti,fifo-depth = <0x1>;
ti,rxctrl-strap-worka;
stephenm
Are you saying that if you dont enable the gem it works fine?
Can you verify the SD config in the zynq ps in vivado to make sure this is correct as per your board.
are you using a custom board? Have you tested this in bare metal?
