Voyager
Voyager
XSCT inside Docker container
Hi all,
I would like to build our Yocto images inside Docker container. Docker build seems okay but during the run Yocto complains about xsct :
NOTE: Fetching xsct binary tarball from http://petalinux.xilinx.com/sswreleases/rel-v2019/xsct-trim/xsct-2019-1.tar.xz;md5sum=7fb75c921050ad579db111906f997681;downloadfilename=xsct_2019.1.tar.xz
NOTE: Extracting external xsct-tarball to sysroots
NOTE: Fetching uninative binary shim from http://downloads.yoctoproject.org/releases/uninative/2.3/x86_64-nativesdk-libc.tar.bz2;sha256sum=c6954563dad3c95608117c6fc328099036c832bbd924ebf5fdccb622fc0a8684
Initialising tasks: 100% |#####################################################################################################################################################################################################| Time: 0:00:01
Sstate summary: Wanted 790 Found 0 Missed 790 Current 0 (0% match, 0% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
| DEBUG: Executing shell function do_configure
| MISC_ARG is -hdf_type hdf -yamlconf /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/device-tree.yaml
| APP_ARG is -app "device-tree"
| Using xsct from:
| cmd is: xsct -sdx -nodisp /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/dtgen.tcl -ws /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/build -pname device-tree -rp /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/git -processor ps7_cortexa9_0 -hdf /home/agent/builddir/tmp/deploy/images/custboard-cpy/Xilinx-custboard-cpy.hdf -arch 32 -app "device-tree" -hdf_type hdf -yamlconf /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/device-tree.yaml
| /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/run.do_configure.29235: line 131: xsct: command not found
| WARNING: /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/run.do_configure.29235:1 exit 127 from 'eval xsct -sdx -nodisp /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/dtgen.tcl -ws /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/build -pname device-tree -rp /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/git -processor ps7_cortexa9_0 -hdf /home/agent/builddir/tmp/deploy/images/custboard-cpy/Xilinx-custboard-cpy.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
| ERROR: Function failed: do_configure (log file is located at /home/agent/builddir/tmp/work/custboard_cpy-distro0x54-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/log.do_configure.29235)
ERROR: Task (/home/agent/yocto/externals/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1608 tasks of which 5 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
/home/build/opt/yocto/externals/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure
It's like xsct is missing, maybe i have one more step to do inside the Dockerfile but i'm stuck :S
Any idea ?
Cheers,
Trigger
Voyager
Voyager
Re: XSCT inside Docker container
Hi all,
Still stuck, I have tried to mount a bind folder and source settings64.sh but same issue...
Cheers,
Trigger
