Observer carlos.aguero
Xilinx Yocto 2018.2 zcu106-zynqmp build issue
I am currently building yocto images for an zcu106-zynqmp http://www.wiki.xilinx.com/How%20to%20build%20images%20through%20yocto but at the build process I get this error at btrfs-tools:
Log data follows:
| DEBUG: SITE files ['endian-little', 'bit-64', 'arm-common', 'arm-64', 'common-linux', 'common-glibc', 'aarch64-linux', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8
|     [LD]     btrfs
|     [LD]     btrfs-map-logical
|     [LD]     btrfs-image
|     [LD]     btrfs-zero-log
|     [LD]     btrfs-find-root
|     [LD]     btrfstune
|     [LD]     btrfs-select-super
|     [LD]     btrfs-convert
|     [LD]     btrfs-corrupt-block
| cmds-check.o: In function `cmd_check':
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:12948: undefined reference to `print_extent_state'
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:12939: undefined reference to `qgroup_verify_all'
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:12942: undefined reference to `report_qgroups'
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:13188: undefined reference to `free_qgroup_counts'
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:13136: undefined reference to `qgroup_verify_all'
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:13142: undefined reference to `report_qgroups'
| /usr/src/debug/btrfs-tools/4.12-r0/git/cmds-check.c:13143: undefined reference to `repair_qgroups'
| collect2: error: ld returned 1 exit status
| Makefile:372: recipe for target 'btrfs' failed
| make: *** [btrfs] Error 1
| make: *** Waiting for unfinished jobs....
Have you seen this error, when trying to build: MACHINE=zcu106-zynqmp bitbake petalinux-image-minimal
Regards and thank you for your time.
https://developer.ridgerun.com/wiki/index.php?title=RidgeRun_Professional_Services
Re: Xilinx Yocto 2018.2 zcu106-zynqmp build issue
cleanall the btrfs-tools and rebuild, btrfs-tools building now without problems, thank you.
Hi @carlos.aguero,
Can you post your local.conf configurations?
Sandeep
Hi @sandeepg
Sure this is my local.conf, removed comments in order to make the post smaller:
#------------ local.conf init ------------
MACHINE ??= "zcu106-zynqmp"
DL_DIR ?= "/opt/yocto/downloads"
SSTATE_DIR ?= "/opt/yocto/sstate"
DISTRO ?= "petalinux"
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
    STOPTASKS,${TMPDIR},1G,100K \
    STOPTASKS,${DL_DIR},1G,100K \
    STOPTASKS,${SSTATE_DIR},1G,100K \
    STOPTASKS,/tmp,100M,100K \
    ABORT,${TMPDIR},100M,1K \
    ABORT,${DL_DIR},100M,1K \
    ABORT,${SSTATE_DIR},100M,1K \
    ABORT,/tmp,10M,1K"
XILINX_VER_MAIN = "2018.2"
XILINX_SDK_TOOLCHAIN = "/opt/Xilinx/SDK/2018.2"
CONF_VERSION = "1"
#------------ local.conf end ------------
Regards.
