esraaltun
Xsct Problem : Cortex-A53 #0 (No Power)
I'm working with zcu102 and I'm accessing from remote. I want to reset zcu102 using xsct before I boot the petalinux project from jtag. However, I sometimes face this issue "Cortex-A53 #0 (No Power)"
1* PS TAP
2 PMU
4 PL
5 PSU
6 RPU (Reset)
7 Cortex-R5 #0 (RPU Reset)
8 Cortex-R5 #1 (RPU Reset)
9 APU (L2 Cache Reset)
10 Cortex-A53 #0 (No Power)
11 Cortex-A53 #1 (No Power)
12 Cortex-A53 #2 (APU Reset)
13 Cortex-A53 #3 (APU Reset)
I don't reset this state on zcu102. How to solve this problem without using hard reset?
Or how to switch other A53 Core for booting the system?
esraaltun
Additionally, I change the kernel configuration like https://www.xilinx.com/support/answers/69143.html but not any change
I tried to boot the system using Cortex-A53 #2 but I was facing some issues.
xsdb% targets
1 PS TAP
2 PMU
3 PL
4 PSU
5 RPU (Reset)
6 Cortex-R5 #0 (RPU Reset)
7 Cortex-R5 #1 (RPU Reset)
8* APU (L2 Cache Reset)
9 Cortex-A53 #0 (No Power)
10 Cortex-A53 #1 (No Power)
11 Cortex-A53 #2 (APU Reset)
12 Cortex-A53 #3 (APU Reset)
xsdb% targets -set -filter {name =~ "Cortex-A53 #2"}
xsdb% rst -processor
xsdb% Info: Cortex-A53 #2 (target 11) Stopped at 0xffff0000 (Reset Catch)
xsdb% dow zynqmp_fsbl.elf
Downloading Program -- /home/phy/Documents/petalinux/images/linux/zynqmp_fsbl.elf
section, .text: 0xfffc0000 - 0xfffd285b
section, .init: 0xfffd2880 - 0xfffd28b3
section, .fini: 0xfffd28c0 - 0xfffd28f3
section, .note.gnu.build-id: 0xfffd28f4 - 0xfffd2917
section, .rodata: 0xfffd2940 - 0xfffd2e47
section, .sys_cfg_data: 0xfffd2e80 - 0xfffd3717
section, .mmu_tbl0: 0xfffd4000 - 0xfffd400f
section, .mmu_tbl1: 0xfffd5000 - 0xfffd6fff
section, .mmu_tbl2: 0xfffd7000 - 0xfffdafff
section, .data: 0xfffdb000 - 0xfffdc3a7
section, .sbss: 0xfffdc3a8 - 0xfffdc3bf
section, .bss: 0xfffdc3c0 - 0xfffde67f
section, .heap: 0xfffde680 - 0xfffdea7f
section, .stack: 0xfffdea80 - 0xfffe0a7f
section, .dup_data: 0xfffe0a80 - 0xfffe1e27
section, .handoff_params: 0xfffe9e00 - 0xfffe9e87
section, .bitstream_buffer: 0xffff0040 - 0xfffffc3f
100% 0MB 0.2MB/s 00:00
Setting PC to Program Start Address 0xfffc0000
Successfully downloaded /home/phy/Documents/petalinux/images/linux/zynqmp_fsbl.elf
xsdb% con
Info: Cortex-A53 #2 (target 11) Running
xsdb% stop
Info: Cortex-A53 #2 (target 11) Stopped at 0xfffcf240 (External Debug Request)
xsdb% dow -data Image 0x3000000
100% 26MB 0.2MB/s 02:15
Successfully downloaded /home/phy/Documents/petalinux/images/linux/Image
xsdb% dow u-boot.elf
Downloading Program -- /home/phy/Documents/petalinux/images/linux/u-boot.elf
section, .data: 0x08000000 - 0x080b1e3b
100% 0MB 0.2MB/s 00:03
Setting PC to Program Start Address 0x08000000
Successfully downloaded /home/phy/Documents/petalinux/images/linux/u-boot.elf
xsdb% dow -data system.bit
Failed to download /home/phy/Documents/petalinux/images/linux/system.bit
can't read "address": no such variable
xsdb% dow -data system.bit 0x2000000
100% 25MB 0.2MB/s 02:09
Successfully downloaded /home/phy/Documents/petalinux/images/linux/system.bit
xsdb% On
On minicom terninal
How to can I use other cores for booting the system?
jrhtech
Voyager
Voyager
Still not fixed in 2020.1 despite what this says:
https://www.xilinx.com/support/answers/72456.html
putting the rpu elf in the boot.bin did allow me to attach via vitis
jeff
jrhtech
Voyager
Voyager
Sorry, I just looked at this again and saw it was no power on the A53.  The problem I had and still exist is on the R5s.
jeff
