mgillott
ZC702 Base TRD 2015.4. Why uImage and not image.ub?
Just finished building the linux image for the ZC702 base targeted ref design with petalinux 2015.4
In the build, the kernel is packaged as uImage, then this, the devicetree and ramdisc image are copied to the SD card
In Petalinux Reference Guide UG1144 it is the FIT image.ub that is copied to SD.
So why does btrd use uImage +dt + ramdisc ?
(I tried booting from image.ub produced by the btrd build. Kernel starts but cant find ramdisc.)
Malcolm
ckohn
Hi Malcolm,
I would say it's for historic reasons. In the past, the Base TRD supplied two different device-tree files, one that worked with the HDMI daughter card and the other without. Therefore, it was much easier to not include the dt in the image file so one can easily switch between different device trees without having to rebuild image.ub.
That being said, you should be able to use image.ub but you will have to rebuild u-boot in a different configuration as u-boot currently expects uImage + dt + ramdisk. Now I haven't tried this myself, but if you run petalinux-config and set u-boot to auto-config, it should select image.ub as the default boot flow. Of course you also have to rebuild your BOOT.bin now.
Hope this helps!
Chris
ckohn
Hi Malcolm,
Hope this helps!
Chris
mgillott
Chris
Thanks for the answers - both to my question posed, and to an un-asked question about u-boot config
Thanks and Regards!
Malcolm
