JWMISEU
ZCU102 Petalinux Build: petalinux_hsm_bridge.tcl not found while building device-tree
I am making a Petalinux 2020.2 build for our ZCU102, which includes the meta-ros layers for ROS2 Foxy.
The build fails while making the pcl (Point Cloud Library) recipe for the meta-ros-common layer, which I think is an out-of-memory error, so I am trying to build pcl separately, using bitbake pcl. This, however, fails on the device-tree recipe. Doing bitbake pcl reveals:
couldn't read file "/etc/hsm/scripts/petalinux_hsm_bridge.tcl": no such file or directory
This file is installed in
my_petalinux_dir/etc/hsm/scripts/
 So, it's just the wrong prefix being used.
How can I fix this problem?
vishu26
I have the similar problem when I run the following command.
bitbake petalinux-image-minimal -c do_populate_sdk
I am running petalinux 2020.2. @JWMISEU which version of petalinux are you using?
Thanks & Regards
Vishav
hokim
The following is required to enable bitbake in petalinux
$ source components/yocto/layers/core/oe-init-build-env
$ export BB_ENV_EXTRAWHITE="$BB_ENV_EXTRAWHITE PETALINUX"
You can't locate and execute  xsct  script(petalinux_hsm_bridge.tcl)  without export and it causes device-tree build error
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug1144-petalinux-tools-reference-guide.pdf#page=173
<peta-proj>/meta-user/recipes-bsp/device-tree/device-tree.bbappend
export PETALINUX
do_configure_append () {
    script="${PETALINUX}/etc/hsm/scripts/petalinux_hsm_bridge.tcl"
    data=${PETALINUX}/etc/hsm/data/
    eval xsct -sdx -nodisp ${script} -c ${WORKDIR}/config \
    -hdf ${DT_FILES_PATH}/hardware_description.${HDF_EXT} -repo ${S} \
    -data ${data} -sw ${DT_FILES_PATH} -o ${DT_FILES_PATH} -a "soc_mapping"
https://www.yoctoproject.org/docs/3.0/bitbake-user-manual/bitbake-user-manual.html#var-bb-BB_ENV_WHITELIST
