Visitor dave0132
ZCU102 QuadSPI implementaion with Petalinux
I have a ZCU102 board that I am trying to get working with a the quad SPI core in PL. I need to have the system running linux, and I need to use the HDMI output. I have started with the ZCU102 TRD Ubuntu tutorial. The example uses Vivado 2017.4. I have built tha hardware and Petalinux project successfully. I now want to add a  AXI Quad SPI core and have access to it from the OS.
I have searched all over and pieced together a number of examples, all based on Zynq systems (Zybo, Zedboards, ertc). I have been working at implementing the SPIDEV driver. One example I followed was the MiniZed I2C and SPI tutorial. It all seemed straight forward, but I cannot get anything to work. I am using 2017.4 tools.  I simply added the AXI Quad SPI core to the block diagram. The system already has numerous interrupts implented, I increased the size of the concat block and added the SPI insterrupt. The hardware implements and exports fine.
Now I cannot get Petalinux to compile.
I have added various definitions to the kernel cfg files:
CONFIG_SPI_DEV=y
CONFIG_SPI_XILINX=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_BITBANG=y
 and added  to the sytem-user.dtsi
&axi_quad_spi_0 {
is-decoded-cs = <0>;
num-cs = <1>;
status = "okay";
spidev@0 {
compatible = "spidev";
spi-max-frequency = <10000000>;
reg = <0>;
Building with these additions produces an error: Label or path axi_quad_spi_0 not found.
I have tried various combinations of the above configurations to try and isolate teh problem, but it just seems that I am missing something.
I woudl appreciate it if someone can point me in some direction to move me forward, I am stuck.
Petalinux error message:
fsbl-2017.1+gitAUTOINC+3813f14966-r0 do_compile: NOTE: fsbl: compiling from external source tree /opt/pkg/petalinux/2017.1/tools/hsm/data/embeddedsw
ERROR: device-tree-generation-xilinx+gitAUTOINC+94fc615234-r0 do_compile: Function failed: do_compile (log file is located at /home/user/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+94fc615234-r0/temp/log.do_compile.31464)
ERROR: Logfile of failure stored in: /home/user/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+94fc615234-r0/temp/log.do_compile.31464
Log data follows:
| DEBUG: Executing shell function do_compile
| Error: /home/user/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+94fc615234-r0/pl.dtsi:18.1-16 Label or path axi_quad_spi_0 not found
| FATAL ERROR: Syntax error parsing input tree
| WARNING: /home/user/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+94fc615234-r0/temp/run.do_compile.31464:1 exit 1 from 'dtc -I dts -O dtb -R 8 -p 0x1000 -i /home/david/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+94fc615234-r0 -i /home/david/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree-generation -o /home/david/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree-generation/plnx_aarch64-system.dtb /home/david/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/../components/plnx_workspace/device-tree-generation/plnx_aarch64-system.pp'
| ERROR: Function failed: do_compile (log file is located at /home/user/plxprjs/rdf0421-zcu102-base-trd-2017-1/apu/petalinux_bsp/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+94fc615234-r0/temp/log.do_compile.31464)
ERROR: Task (/opt/pkg/petalinux/2017.1/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/device-tree/device-tree-generation_git.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6066 tasks of which 6048 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
webtalk failed:PetaLinux statistics:extra lines detected:notsent_nofile!
webtalk failed:Failed to get PetaLinux usage statistics!
Visitor dave0132
Re: ZCU102 QuadSPI implementaion with Petalinux
I posted this question because I was at a loss after reading and researching for days. but I finally figured out what was wrong. The autoconfigure setting for the device tree was disabled, so my custom component was not created in the device tree when I imported the HDF file.
