dnicholes
ZCU111 Serial output is incomplete
I am working on getting Petalinux to boot. There is an error somewhere but the serial output looks incomplete. This is an example:
         ###################################################+ OK
   Using 'conf@system-top.dtb' configuration
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Compression:  uncompressed
     Data Start:   0x1113ec0c
     Data Size:    4331[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with c] smp: Brought up 1 node, 4 CPUs
[    0.095672] SMP: Total of 4 processors activated.
[    0.100345] CPU features: detected: 32-bit EL0 Support
[    0.106980] CPU: All CPU(s) started[    0.177110]    8regs     :  2375.000 MB/sec
_), 1 data @ (____ptrval____))
[    0.335449] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.342865] DMA: preallocated 256 KiB pool for atomic allocations
[    0.361854] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.771078] raid6: int64x4  xor()   736 MB/s
[    0.907186] raid6: int64x8  xor()   759 MB/s
[    0.975224] raid6: neonx1   gen()   737 MB/s
[    1.179347] raid6: neonx2   xor()  1172 MB/s
[    1.315423] raid6: neonx4   xor()  1417 MB/s
[    1.451519] raid6: neonx8   xor()  1459 MB/s
[    1.451557] raid6: using algorithm neonx8 gen() 1542 MB/s
[    1.455509] raid6: .... xor() 1459 MB/s, rmw enabled
[    1.460440] raid6: using neon recovery algorithm
ed   1.465798] SCSI subsystem initialized
[    2.844918] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.852256] io scheduler noop registered
[    2.856142] io scheduler deadline registered
[    2.860399] io scheduler cfq registered (default)
[    2.865053] io scheduler mq-deadline registered
[    2.869550] io scheduler kyber registered
sbcore: registered new interface driver ax88179_178a
[    2.945282] usbcore: registered new interface driver cdc_ether
[    2.951075] usbcore: registered new interface driver net1080
[    2.956698] usbcore: registered new interface driver cdc_subset
[    2.962579] usbcore: registered new interface driver zaurus
[    2.968123] usbcore: registered new interface driver cdc_ncm
[    2.974223] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.980204] ehci-pci: EHCI PCI platform driver
[    2.984883] usbcore: registered new interface driver uas
[    2.989923] usbcore: registered new interface driver usb-storage
[    2.996378] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    3.003097] i2cs zynqmp_aes: AES Successfully Registered
[    3.178549]
[    3.186004] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    3.192120] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    3.197707] usbcore: registered new interface driver usbhid
[    3.203030] usbhid: USB HID core driver
[    3.209097] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager regiqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.562550] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.575295] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[    3.5d.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[    4.904852] xhci-hcd xhci-hcd.0.auto: irq 47, io mem 0xfe200000
[    4.910976] usb usb1: New USB dev
stephenm
Are you connected to the Xilinx debug tools; XSCT, Vitis, HW_SERVER ect? If so, then the issue might be the CPU IDLING:
https://www.xilinx.com/support/answers/69143.html
dnicholes
This problem was resolved when I disconnected and reconnected the USB cable. It was a very strange issue.
