08-21-2020 02:33 AM
Hi ,
I am trying to build zybo z7-20 mipi cam application using https://github.com/Digilent/Zybo-Z7-20-pcam-5c/releases/tag/v2018.2-2 with Vivado 2018.2 and petalinux 2018.2.
The project from this git is able to generate bit stream; however when this repo is with SDK solution and i want it to run on petalinux. I tried building petalinux it shows device tree error .
Do i need to change the device tree ? if yes how?
do i need to change yocto settings?
08-23-2020 05:21 PM
Hello @shreyas_borse
This is a design from Digilent, which I guess only designed for a baremetal environment.
Could you please ask Digilent an assistance for this ?
Please report the issue here : https://github.com/Digilent/Zybo-Z7-20-pcam-5c/issues
Kind regards
Leo
