analoglamb
Zynq MPSOC Reboot Failed in FSBL
 Hi Xilinx
I am using ZCU102 and Petalinux 2019.2 to Test Watchdog Timer as Xilinx Wiki,https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842055/Cadence+WDT+Driver. But after the watchdog timer timeout, It reboots failed on FSBL, the log as below, If I use the reboot command in Linux, It's same.
Rebooting... [  723.888220] reboot: Restarting system
Xilinx Zynq MP First Stage Boot Loader
Release 2019.2   Aug  3 2020  -  10:56:58
Reset Mode      :       System Reset
Platform: Silicon (4.0), Cluster ID 0x80000000
Running on A53-0 (64-bit) Processor, Device Name: XCZU9EG
FMC VADJ Configuration Successful
Board Configuration successful
Processor Initialization Done
================= In Stage 2 ============
SD1 with level shifter Boot Mode
SD: rc= 0
File name is BOOT.BIN
Multiboot Reg : 0x0
Image Header Table Offset 0x8C0
*****Image Header Table Details********
Boot Gen Ver: 0x1020000
No of Partitions: 0x4
Partition Header Address: 0x440
Partition Present Device: 0x0
Initialization Success
======= In Stage 3, Partition No:1 =======
UnEncrypted data Length: 0x65216F
Data word offset: 0x65216F
Total Data word length: 0x65216F
Destination Load Address: 0xFFFFFFFF
Execution Address: 0x0
Data word offset: 0x109B0
Partition Attributes: 0x26
Destination Device is PL, changing LoadAddress
XPFW: Calling ROM PWRUP Handler..Done
XPFW: Calling ROM Isolation Handler..Done
Non authenticated Bitstream download to start now
DMA transfer done
PL Configuration done successfully
aPFW: Calling ROM PWRUP Handler..DoneP
 rtition 1 Load Success
======= In Stage 3, Partition No:2 =======
UnEncrypted data Length: 0x31DE
Data word offset: 0x31DE
Total Data word length: 0x31DE
Destination Load Address: 0xFFFEA000
Execution Address: 0xFFFEA000
Data word offset: 0x662B20
Partition Attributes: 0x117
SD: f_read returned 1
XFSBL_ERROR_SD_F_READ
Partition 2 Load Failed, 0x2B
================= In Stage Err ============
Fsbl Error Status: 0x0
But if I power on zcu102, It boots well, the log as below
SD: rc= 0
Multiboot Reg : 0x0
DMA transfer done
PaFW: Calling ROM PWRUP Handler..Done
Partition 2 Load Success
======= In Stage 3, Partition No:3 =======
UnEncrypted data Length: 0x32976
Data word offset: 0x32976
Total Data word length: 0x32976
Destination Load Address: 0x8000000
Execution Address: 0x8000000
Data word offset: 0x665D00
Partition Attributes: 0x114
Partition 3 Load Success
All Partitions Loaded
================= In Stage 4 ============
Protection configuration applied
Running A▒▒}M▒▒▒▒ձ▒▒I▒▒▒ٕQ▒ͭ Removed 1 tasks
NOTICE:  ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v2.0(release):xilinx-v2019.1-12-g713dace9
NOTICE:  BL31: Built : 09:08:18, Aug  3 2020
Copied FSBL image to DDR and image hash checksum calculation successful
XPfw_SchedulerRemoveTask: Removed 1 tasks
PMUFW:  v1.1
Please help me solve the problem as soon as possible, Thanks
Tags (2)
chaoz
@analoglamb
Could you read BootROM error after reboot failure?
You can refer to UG1085 for bootrom error codes information.
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
chaoz
@analoglamb
analoglamb
Thanks, I find out the problem is led by sd card, no matters with petalinux. Use another SD card, It works well.
Thanks again
