astaffen
Zynq Qt/Qwt libraries: QtCore/include/qatomic_arm.h:131: Error: no such instruction...
I have built the Zynq Qt/Qwt libraries as it is explained on http://wiki.xilinx.com/zynq-base-trd-qt.
All went well until I tried to import the sobel_qt example project (Zynq-7000 Base TRD 14.3) into SDK.
First of all I changed the install path of the Qt/Qwt library to my install path and then started to build the sobel_qt project.
But then I got the following error messages:
QT_INSTALL/include/QtCore/qatomic_arm.h:131: Error: no such instruction: `swpb %al,%r13b,[%rbx]'
QT_INSTALL/include/QtCore/qatomic_arm.h:131: Error: no such instruction: `swpb %cl,%dl,[%rbx]'
etc.
(The error messages are repeated for several times.)
Can anybody help me out of that?
I'm using ubuntu 12.04 and Xilinx ISE Design Suite 14.3.
i.panchenko
Hello! Have the same error! Have you fixed it?
yasemin.ali.87
Same here
My Environment redhat 6.4, ISE 14.7 and vivado 2014.2
../../include/QtCore/../../src/corelib/arch/qatomic_arm.h: Assembler messages:
../../include/QtCore/../../src/corelib/arch/qatomic_arm.h:131: Error: no such instruction: `swpb %al,%bpl,[%rbx]'
../../include/QtCore/../../src/corelib/arch/qatomic_arm.h:131: Error: no such instruction: `swpb %cl,%dl,[%rbx]'
../../include/QtCore/../../src/corelib/arch/qatomic_arm.h:131: Error: no such instruction: `swpb %al,%r12b,[%rbp]'
../../include/QtCore/../../src/corelib/arch/qatomic_arm.h:131: Error: no such instruction: `swpb %cl,%al,[%rbp]'
../../include/QtCore/../../src/corelib/arch/qatomic_arm.h:131: Error: no such instruction: `swpb %al,%r12b,[%rbx]'
........ repeated with different swpb ..........
make[1]: *** [.obj/release-shared-emb-arm/qabstractanimation.o] Error 1
make[1]: Leaving directory Qt/build/qt-everywhere-opensource-src-4.7.3/src/corelib'
I follow steps here http://www.wiki.xilinx.com/Zynq+Qt+and+Qwt+Base+Libraries-Build+Instructions
then i use modification in qmake from this http://www.xilinx.com/support/answers/59172.html
but the same error appears
Please I need a help as soon as possible
Thank you
milekro
Does someone solved this error?
greetings...
milekro
radheys
Can you check if CROSS_COMPILE environment variable is set.
export CROSS_COMPILE=arm-xilinx-linux-gnueabi-
Hope it helps.
-Radhey
tmcdowe
the AR below details the overall flow for this sort of thing (with PetaLinux as the build flow).  It might be helpful to consult this and see if you're missing a step:
this space intentionally left blank
