chungae9ri
Zynq uart is disabled in device tree
Using custom board with zynq7000, vivado 2018.3 and petalinux 2018.3, I enabled the uart 0 (MIO 14, 15), uart 1 (MIO 12, 13) in vivado block design. After I built the image.ub, there is no petalinux console messages to my desktop terminal screen. When I check the zynq-7000.dtsi, the status of uart 0 and 1 is "disabled". Even I manually set it "okay", it is reset to "disabled" when image.ub is built. I double checked the vivado zynq7 IO configuration and it is properly enabled.
How can I change the uart 0/1 to be enabled and see the petalinux message in the serial terminal?
pvenugo
Hi @chungae9ri ,
For  "When I check the zynq-7000.dtsi, the status of uart 0 and 1 is "disabled". Even I manually set it "okay", it is reset to "disabled" when image.ub is built. "
you need to overwrite the status to "okay" in system-user.dtsi as said earlier. Later build petalinux image and check status in system.dtb file converted to dts file.
"How can I change the uart 0/1 to be enabled and see the petalinux message in the serial terminal?  "
Also, you could dmesg | grep uart post linux boot to know which ttyPS* it is assigned to.
Refer, to https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842340/PS+UART for more checks.
Praveen
ritakur
please try to set okay in system-user.dtsi.
stephenm
The devicetree generator uses the HDF to generate the devicetree automatically. So, if you have the uart enabled in the vivado, and export to SDK. this should enabled this in the devictree.
You can of course set this to okay in the system-user.dtsi. However, I would rather check you HDF to make sure everything is ok here.
chungae9ri
I definitely enabled the UART in my vivado design. Is there any other way to check the UART enablement in vivado design?
stephenm
Can you post your hdf file?
The device tree generator uses HSI to extract the info
You can try the following in HSI (from XSCT or HSI)
hsi::open_hw_design path/to/hdf.hdf
hsi::get_cells -filter {IS_PL==1}
You should see all the ip in the pl here. Make sure your uart is here.
If so, then just manually update the system-user.dtsi to enable this, and update your alias. You can also manually update the bootargs here to to add the console manually too
stephenm
pvenugo
Hi @chungae9ri ,
Praveen
