dcorreia2
Zynq702 uboot watchdog enable
I am looking for an example on how to enable the watchdog timer in uboot. I am building a custom project using Yocto I am using the u-boot-xlnx repository for uboot.
I know I have to enable the variable CONFIG_HW_WATCHDOG but where do I define the code to setup the watchdog.
austin
http://www.wiki.xilinx.com/Axi+Watchdog
Austin Lesea
Principal Engineer
Xilinx San Jose
dcorreia2
I need to know how to enable it in uboot. I already have it running in Linux.
pritya
Hello all,
Did anybody got any workaround/solution on how to enable WDT in u-boot ?
There is no menu w.r.t WDT in u-boot menuconfig & Kconfig file of watchdog drivers is empty.
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/watchdog/Kconfig
Suppose if I want to test Xilinx WDT driver in U-boot how do I do this?
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/watchdog/xilinx_tb_wdt.c
Any help will be appreciated.
imshedi
I got something working from my side. Please try it and share your experience. I tried it on Petalinx-2016.4 & U-boot 2016.7 (Which comes by default with plnx-2016.4)
Have made some tweaks to try WDT functionalities. Please go through the attached patch file & use only the things you need.
Good luck.
