ZynqMP USB OTG problems in Petalinux 2018.1
Hi There !
We have a composite USB Gadget that worked fine in PL 2017.3. After plugging into a windows machine we got the expected Serial & HID device. However, after upgrading to PL 2018.1 it is no longer working. See log below.
[ 103.396526] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 122.905491] dwc3 fe300000.dwc3: dwc3_otg_irq(): B-Device VBUS Change Event
[ 122.905807] dwc3 fe300000.dwc3: check_event(): Event occurred: otg_events=80000102, otg_mask=1000100, user_events=0, user_mask=47
[ 122.905813] dwc3 fe300000.dwc3: do_b_peripheral(): OEVT_B_DEV_VBUS_CHNG_EVNT
[ 122.905817] dwc3 fe300000.dwc3: do_b_peripheral(): Session not valid
[ 122.905822] dwc3 fe300000.dwc3: stop_peripheral():
[ 122.905826] dwc3 fe300000.dwc3: stop_peripheral(): disabled ep in gadget driver
[ 122.932512] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_B_IDLE
[ 122.932517] dwc3 fe300000.dwc3: do_b_idle():
[ 122.932522] dwc3 fe300000.dwc3: set_peri_mode(): set OCTL PERI_MODE = 1 in OCTL
[ 122.932528] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 132.960644] dwc3 fe300000.dwc3: dwc3_otg_irq(): B-Device Session Valid Detect Event
[ 132.960652] dwc3 fe300000.dwc3: dwc3_otg_irq(): B-Device VBUS Change Event
[ 132.960674] dwc3 fe300000.dwc3: check_event(): Event occurred: otg_events=8000030a, otg_mask=1000300, user_events=0, user_mask=1
[ 132.960679] dwc3 fe300000.dwc3: do_b_idle(): OEVT_B_DEV_VBUS_CHNG_EVNT
[ 132.960683] dwc3 fe300000.dwc3: do_b_idle(): Session valid
[ 132.960688] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_B_PERIPHERAL
[ 132.960692] dwc3 fe300000.dwc3: stop_host():
[ 132.960697] dwc3 fe300000.dwc3: stop_host(): INFO: Host already stopped
[ 132.960701] dwc3 fe300000.dwc3: start_peripheral():
[ 132.960706] dwc3 fe300000.dwc3: set_peri_mode(): set OCTL PERI_MODE = 1 in OCTL
[ 132.961375] dwc3 fe300000.dwc3: do_b_peripheral():
[ 153.968499] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 153.973906] 2-...: (1 GPs behind) idle=2f6/140000000000000/0 softirq=14070/14070 fqs=2118
[ 153.982232] (detected by 1, t=5255 jiffies, g=11969, c=11968, q=6960)
[ 153.988743] Task dump for CPU 2:
[ 153.988746] otg R running task 0 1969 2 0x00000002
[ 153.988753] Call trace:
[ 153.988768] [<ffffff80080858a0>] __switch_to+0x98/0xb0
[ 153.988771] [<0000000000000003>] 0x3
Plugging in a USB memory stick works, so Host mode is OK.
I tried the OTG test procedure here http://www.wiki.xilinx.com/Zynq+Ultrascale+MPSOC+Linux+USB+device+driver and it behaves the same.
Any ideas on what it could be ?
/Otto
Hi Otto,
Please try with below device tree and config changes
vim project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
&dwc3_0 {
  dr_mode = "otg";
  maximum-speed = "high-speed";
  snps,dis_u2_susphy_quirk;
petalinux-config -c kernel
Add below configurations via menuconfig
    CONFIG_PM=y
    CONFIG_USB_OTG=y
    CONFIG_USB_OTG_FSM=y
        Select below option.
        DWC3 Mode Selection (Dual Role mode + OTG)  --->
    CONFIG_USB_DWC3_OTG=y
Steps to test OTG
When the Linux kernel boots up, give the below commands:
$ dd if=/dev/zero of=/tmp/mydev count=256 bs=1M
$ modprobe g_mass_storage file=/tmp/mydev removable=1 stall=1 iSerialNumber=7ABC7ABC7ABC7ABC7ABC7ABC
Peripheral Mode
Connect board to any Host PC via USB Std-A-Male to Micro-B-Male cable.
It should be detected as a Mass Storage Device
Do some data transfers
Host Mode
Connect any pen-drive with the board via USB Micro-A-Male to Std-A-Female type connector
Check that the pen-drive is detected properly
Do some data transfers.
Note : Both Host and Peripheral mode should work without resetting/rebooting the board.
Make sure jumpers settings as per OTG.
Thanks & regards
Aravind
Hi Aravind,
This works well on the zcu102 board, but unfortunately not on ours. Not sure if it as something to do with us using the second usb controller, instead of the first that the zcu102 board uses. Btw, we do use the first controller in USB 3.0 Host mode and that works great.
/Otto
Hi Otto,
if you use second usb controller, add the device tree like below and try , it should work.
&dwc3_1 {
  dr_mode = "otg";
&usb1{
status="okay";
Thanks & regards
Aravind
Hi Aravind !
Unfortunately it does not for us. I added a lot of debugging output and compared the working zcu102 with our board. After connecting the port to a PC, the first difference/error we get is a timeout on line 384 in dwc3_send_gadget_ep_cmd().
Also, when connecting a USB stick (Host mode) I get some messages printing out initially, but then it takes 500s before the device will actually enumerate properly. See below for that Log
dwc3 fe300000.dwc3: dwc3_otg_irq(): Connector ID Status Change Event
[ 24.676709] dwc3 fe300000.dwc3: check_event(): Event occurred: otg_events=1000000, otg_mask=1000300, user_events=0, user_mask=1
[ 24.688491] dwc3 fe300000.dwc3: do_b_idle(): OEVT_CONN_ID_STS_CHNG_EVNT
[ 24.695081] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_UNDEFINED
[ 24.701587] dwc3 fe300000.dwc3: do_connector_id_status():
[ 24.772588] dwc3 fe300000.dwc3: do_connector_id_status(): Connector ID is A
[ 24.779477] dwc3 fe300000.dwc3: init_a_device(): Write 0 to OCFG and OCTL
[ 24.844611] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_A_IDLE
[ 24.850801] dwc3 fe300000.dwc3: stop_peripheral():
[ 24.855659] dwc3 fe300000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
[ 24.863298] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_A_WAIT_VRISE
[ 24.870068] dwc3 fe300000.dwc3: do_a_wait_vrise():
[ 24.874926] dwc3 fe300000.dwc3: start_host():
[ 24.879353] dwc3 fe300000.dwc3: set_peri_mode(): set OCTL PERI_MODE = 0 in OCTL
[ 24.886655] dwc3 fe300000.dwc3: start_host(): hcd=ffffffc0254c4000 xhci=ffffffc0254c4228
[ 24.894727] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 24.900219] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 24.907847] xhci-hcd xhci-hcd.0.auto: xHCI capability registers at ffffff800c5b0000:
[ 24.915554] xhci-hcd xhci-hcd.0.auto: CAPLENGTH AND HCIVERSION 0x1000020:
[ 24.922321] xhci-hcd xhci-hcd.0.auto: CAPLENGTH: 0x20
[ 24.927356] xhci-hcd xhci-hcd.0.auto: HCIVERSION: 0x100
[ 24.932561] xhci-hcd xhci-hcd.0.auto: HCSPARAMS 1: 0x2000440
[ 24.938207] xhci-hcd xhci-hcd.0.auto: Max device slots: 64
[ 24.943845] xhci-hcd xhci-hcd.0.auto: Max interrupters: 4
[ 24.949403] xhci-hcd xhci-hcd.0.auto: Max ports: 2
[ 24.954347] xhci-hcd xhci-hcd.0.auto: HCSPARAMS 2: 0xc0000f1
[ 24.959992] xhci-hcd xhci-hcd.0.auto: Isoc scheduling threshold: 1
[ 24.966327] xhci-hcd xhci-hcd.0.auto: Maximum allowed segments in event ring: 15
[ 24.973885] xhci-hcd xhci-hcd.0.auto: HCSPARAMS 3 0x7ff000a:
[ 24.979520] xhci-hcd xhci-hcd.0.auto: Worst case U1 device exit latency: 10
[ 24.986641] xhci-hcd xhci-hcd.0.auto: Worst case U2 device exit latency: 2047
[ 24.993930] xhci-hcd xhci-hcd.0.auto: HCC PARAMS 0x238f625:
[ 24.999486] xhci-hcd xhci-hcd.0.auto: HC generates 64 bit addresses
[ 25.005907] xhci-hcd xhci-hcd.0.auto: HC hasn't Contiguous Frame ID Capability
[ 25.013290] xhci-hcd xhci-hcd.0.auto: HC can generate Stopped - Short Package event
[ 25.021098] xhci-hcd xhci-hcd.0.auto: FIXME: more HCCPARAMS debugging
[ 25.027697] xhci-hcd xhci-hcd.0.auto: RTSOFF 0x440:
[ 25.032555] xhci-hcd xhci-hcd.0.auto: xHCI operational registers at ffffff800c5b0020:
[ 25.040371] xhci-hcd xhci-hcd.0.auto: USBCMD 0x0:
[ 25.045054] xhci-hcd xhci-hcd.0.auto: HC is being stopped
[ 25.050609] xhci-hcd xhci-hcd.0.auto: HC has finished hard reset
[ 25.056775] xhci-hcd xhci-hcd.0.auto: Event Interrupts disabled
[ 25.062847] xhci-hcd xhci-hcd.0.auto: Host System Error Interrupts disabled
[ 25.069969] xhci-hcd xhci-hcd.0.auto: HC has finished light reset
[ 25.076215] xhci-hcd xhci-hcd.0.auto: USBSTS 0x1:
[ 25.080904] xhci-hcd xhci-hcd.0.auto: Event ring is empty
[ 25.086457] xhci-hcd xhci-hcd.0.auto: No Host System Error
[ 25.092102] xhci-hcd xhci-hcd.0.auto: HC is halted
[ 25.097049] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0420 port status reg = 0xa000280
[ 25.104604] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0424 port power reg = 0x0
[ 25.111544] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0428 port link reg = 0x0
[ 25.118404] xhci-hcd xhci-hcd.0.auto: ffffff800c5b042c port reserved reg = 0x0
[ 25.125607] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0430 port status reg = 0xa000280
[ 25.133161] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0434 port power reg = 0x0
[ 25.140101] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0438 port link reg = 0x0
[ 25.146961] xhci-hcd xhci-hcd.0.auto: ffffff800c5b043c port reserved reg = 0x0
[ 25.154164] xhci-hcd xhci-hcd.0.auto: // Halt the HC
[ 25.159111] xhci-hcd xhci-hcd.0.auto: Resetting HCD
[ 25.163969] xhci-hcd xhci-hcd.0.auto: // Reset the HC
[ 25.169034] xhci-hcd xhci-hcd.0.auto: Wait for controller to be ready for doorbell rings
[ 25.177078] xhci-hcd xhci-hcd.0.auto: Reset complete
[ 25.182027] xhci-hcd xhci-hcd.0.auto: Enabling 64-bit DMA addresses.
[ 25.188360] xhci-hcd xhci-hcd.0.auto: Calling HCD init
[ 25.193484] xhci-hcd xhci-hcd.0.auto: xhci_init
[ 25.197995] xhci-hcd xhci-hcd.0.auto: xHCI doesn't need link TRB QUIRK
[ 25.204509] xhci-hcd xhci-hcd.0.auto: Supported page size register = 0x1
[ 25.211190] xhci-hcd xhci-hcd.0.auto: Supported page size of 4K
[ 25.217095] xhci-hcd xhci-hcd.0.auto: HCD page size set to 4K
[ 25.222821] xhci-hcd xhci-hcd.0.auto: // xHC can handle at most 64 device slots.
[ 25.230206] xhci-hcd xhci-hcd.0.auto: // Setting Max device slots reg = 0x40.
[ 25.237640] xhci-hcd xhci-hcd.0.auto: // Device context base array address = 0x28064000 (DMA), ffffff8009515000 (virt)
[ 25.248295] xhci-hcd xhci-hcd.0.auto: Allocated command ring at ffffffc025241b00
[ 25.255634] xhci-hcd xhci-hcd.0.auto: First segment DMA is 0x28065000
[ 25.262059] xhci-hcd xhci-hcd.0.auto: // Setting command ring address to 0x0000000028065001
[ 25.270391] xhci-hcd xhci-hcd.0.auto: // xHC command ring deq ptr low bits + flags = @00000000
[ 25.278987] xhci-hcd xhci-hcd.0.auto: // xHC command ring deq ptr high bits = @00000000
[ 25.287012] xhci-hcd xhci-hcd.0.auto: // Doorbell array is located at offset 0x4e0 from cap regs base addr
[ 25.296612] xhci-hcd xhci-hcd.0.auto: // xHCI capability registers at ffffff800c5b0000:
[ 25.304591] xhci-hcd xhci-hcd.0.auto: // @ffffff800c5b0000 = 0x1000020 (CAPLENGTH AND HCIVERSION)
[ 25.313442] xhci-hcd xhci-hcd.0.auto: // CAPLENGTH: 0x20
[ 25.318909] xhci-hcd xhci-hcd.0.auto: // HCIVERSION: 0x100
[ 25.324549] xhci-hcd xhci-hcd.0.auto: // xHCI operational registers at ffffff800c5b0020:
[ 25.332628] xhci-hcd xhci-hcd.0.auto: // @ffffff800c5b0018 = 0x440 RTSOFF
[ 25.339394] xhci-hcd xhci-hcd.0.auto: // xHCI runtime registers at ffffff800c5b0440:
[ 25.347126] xhci-hcd xhci-hcd.0.auto: // @ffffff800c5b0014 = 0x4e0 DBOFF
[ 25.353804] xhci-hcd xhci-hcd.0.auto: // Doorbell array at ffffff800c5b04e0:
[ 25.360837] xhci-hcd xhci-hcd.0.auto: xHCI runtime registers at ffffff800c5b0440:
[ 25.368300] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0440: Microframe index = 0x0
[ 25.375683] xhci-hcd xhci-hcd.0.auto: // Allocating event ring
[ 25.381554] xhci-hcd xhci-hcd.0.auto: TRB math tests passed.
[ 25.387163] xhci-hcd xhci-hcd.0.auto: // Allocated event ring segment table at 0x28068000
[ 25.395298] xhci-hcd xhci-hcd.0.auto: Set ERST to 0; private num segs = 1, virt addr = ffffff8009535000, dma addr = 0x28068000
[ 25.406671] xhci-hcd xhci-hcd.0.auto: // Write ERST size = 1 to ir_set 0 (some bits preserved)
[ 25.415259] xhci-hcd xhci-hcd.0.auto: // Set ERST entries to point to event ring.
[ 25.422723] xhci-hcd xhci-hcd.0.auto: // Set ERST base address for ir_set 0 = 0x28068000
[ 25.430797] xhci-hcd xhci-hcd.0.auto: // Write event ring dequeue pointer, preserving EHB bit
[ 25.439306] xhci-hcd xhci-hcd.0.auto: Wrote ERST address to ir_set 0.
[ 25.445725] xhci-hcd xhci-hcd.0.auto: Allocating 1 scratchpad buffers
[ 25.452195] xhci-hcd xhci-hcd.0.auto: Ext Cap ffffff800c5b08f0, port offset = 1, count = 1, revision = 0x2
[ 25.461790] xhci-hcd xhci-hcd.0.auto: xHCI 1.0: support USB2 software lpm
[ 25.468555] xhci-hcd xhci-hcd.0.auto: xHCI 1.0: support USB2 hardware lpm
[ 25.475325] xhci-hcd xhci-hcd.0.auto: Ext Cap ffffff800c5b0900, port offset = 2, count = 1, revision = 0x3
[ 25.484969] xhci-hcd xhci-hcd.0.auto: Found 1 USB 2.0 ports and 1 USB 3.0 ports.
[ 25.492340] xhci-hcd xhci-hcd.0.auto: USB 2.0 port at index 0, addr = ffffff800c5b0420
[ 25.500239] xhci-hcd xhci-hcd.0.auto: USB 3.0 port at index 1, addr = ffffff800c5b0430
[ 25.508135] xhci-hcd xhci-hcd.0.auto: Finished xhci_init
[ 25.513429] xhci-hcd xhci-hcd.0.auto: Called HCD init
[ 25.518462] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[ 25.527149] xhci-hcd xhci-hcd.0.auto: supports USB remote wakeup
[ 25.533155] xhci-hcd xhci-hcd.0.auto: irq 50, io mem 0xfe300000
[ 25.539036] xhci-hcd xhci-hcd.0.auto: xhci_run
[ 25.543461] xhci-hcd xhci-hcd.0.auto: // xHC command ring deq ptr low bits + flags = @00000000
[ 25.552060] xhci-hcd xhci-hcd.0.auto: // xHC command ring deq ptr high bits = @00000000
[ 25.560041] xhci-hcd xhci-hcd.0.auto: ERST memory map follows:
[ 25.565859] xhci-hcd xhci-hcd.0.auto: @0000000028068000 28067000 00000000 00000100 00000000
[ 25.574189] xhci-hcd xhci-hcd.0.auto: ERST deq = 64'h28067000
[ 25.579919] xhci-hcd xhci-hcd.0.auto: // Set the interrupt modulation register
[ 25.587124] xhci-hcd xhci-hcd.0.auto: // Enable interrupts, cmd = 0x4.
[ 25.593636] xhci-hcd xhci-hcd.0.auto: // Enabling event ring interrupter ffffff800c5b0460 by writing 0x2 to irq_pending
[ 25.604399] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0460: ir_set[0]
[ 25.610648] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0460: ir_set.pending = 0x2
[ 25.617849] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0464: ir_set.control = 0xa0
[ 25.625145] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0468: ir_set.erst_size = 0x1
[ 25.632520] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0470: ir_set.erst_base = @28068000
[ 25.640421] xhci-hcd xhci-hcd.0.auto: ffffff800c5b0478: ir_set.erst_dequeue = @28067000
[ 25.648581] xhci-hcd xhci-hcd.0.auto: Finished xhci_run for USB2 roothub
[ 25.655345] usb usb1: default language 0x0409
[ 25.659662] usb usb1: udev 1, busnum 1, minor = 0
[ 25.664317] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 25.671084] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 25.678288] usb usb1: Product: xHCI Host Controller
[ 25.683146] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.1 xhci-hcd
[ 25.689832] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 25.694988] usb usb1: usb_probe_device
[ 25.698684] usb usb1: configuration #1 chosen from 1 choice
[ 25.704232] xHCI xhci_add_endpoint called for root hub
[ 25.709338] xHCI xhci_check_bandwidth called for root hub
[ 25.714720] xhci-hcd xhci-hcd.0.auto: Endpoint 0x81 ep reset callback called
[ 25.721785] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[ 25.727601] hub 1-0:1.0: usb_probe_interface
[ 25.731800] hub 1-0:1.0: usb_probe_interface - got id
[ 25.736828] hub 1-0:1.0: USB hub found
[ 25.740569] hub 1-0:1.0: 1 port detected
[ 25.744472] hub 1-0:1.0: standalone hub
[ 25.748282] hub 1-0:1.0: no power switching (usb 1.0)
[ 25.753317] hub 1-0:1.0: individual port over-current protection
[ 25.759309] hub 1-0:1.0: Single TT
[ 25.762692] hub 1-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 25.769028] hub 1-0:1.0: power on to power good time: 20ms
[ 25.774526] hub 1-0:1.0: local power source is good
[ 25.779404] hub 1-0:1.0: trying to enable port power on non-switchable hub
[ 25.786223] xhci-hcd xhci-hcd.0.auto: set port power, actual port 0 status = 0xa000280
[ 25.794371] dwc3 fe300000.dwc3: unable to find transceiver
[ 25.799805] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 25.805267] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 25.812905] xhci-hcd xhci-hcd.0.auto: supports USB remote wakeup
[ 25.818881] xhci-hcd xhci-hcd.0.auto: // Turn on HC, cmd = 0x5.
[ 25.824782] xhci-hcd xhci-hcd.0.auto: Finished xhci_run for USB3 roothub
[ 25.831544] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 25.839593] usb usb2: skipped 1 descriptor after endpoint
[ 25.844958] usb usb2: default language 0x0409
[ 25.849316] usb usb2: udev 1, busnum 2, minor = 128
[ 25.854141] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 25.860907] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 25.868112] usb usb2: Product: xHCI Host Controller
[ 25.872969] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.1 xhci-hcd
[ 25.879659] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 25.884784] usb usb2: usb_probe_device
[ 25.888452] usb usb2: configuration #1 chosen from 1 choice
[ 25.894027] xHCI xhci_add_endpoint called for root hub
[ 25.899134] xHCI xhci_check_bandwidth called for root hub
[ 25.904518] xhci-hcd xhci-hcd.0.auto: Endpoint 0x81 ep reset callback called
[ 25.911570] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa000280
[ 25.919613] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x100
[ 25.925980] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 25.926045] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[ 25.926134] hub 2-0:1.0: usb_probe_interface
[ 25.926138] hub 2-0:1.0: usb_probe_interface - got id
[ 25.926146] hub 2-0:1.0: USB hub found
[ 25.926171] hub 2-0:1.0: 1 port detected
[ 25.926176] hub 2-0:1.0: standalone hub
[ 25.926179] hub 2-0:1.0: no power switching (usb 1.0)
[ 25.926182] hub 2-0:1.0: individual port over-current protection
[ 25.926187] hub 2-0:1.0: TT requires at most 8 FS bit times (666 ns)
[ 25.926191] hub 2-0:1.0: power on to power good time: 20ms
[ 25.926215] hub 2-0:1.0: local power source is good
[ 25.926269] usb usb2-port1: peered to usb1-port1
[ 25.926276] hub 2-0:1.0: trying to enable port power on non-switchable hub
[ 25.926284] xhci-hcd xhci-hcd.0.auto: set port power, actual port 0 status = 0xa000280
[ 25.926462] dwc3 fe300000.dwc3: set_capabilities():
[ 25.926466] dwc3 fe300000.dwc3: set_capabilities(): Enabled SRP and HNP capabilities in OCFG
[ 25.926472] dwc3 fe300000.dwc3: start_host(): Port is powered by xhci-hcd
[ 25.926482] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 100
[ 25.926491] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 26.021977] xhci-hcd xhci-hcd.0.auto: Port Status Change Event for port 1
[ 26.021985] xhci-hcd xhci-hcd.0.auto: handle_port_status: starting port polling.
[ 26.028609] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0002a0
[ 26.028613] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x2a0
[ 26.028636] hub 2-0:1.0: state 7 ports 1 chg 0000 evt 0000
[ 26.028655] xhci-hcd xhci-hcd.0.auto: set port remote wake mask, actual port 0 status = 0xe0002a0
[ 26.028668] hub 2-0:1.0: hub_suspend
[ 26.028684] usb usb2: bus auto-suspend, wakeup 1
[ 26.028691] xhci-hcd xhci-hcd.0.auto: xhci_hub_status_data: stopping port polling.
[ 26.028706] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_A_WAIT_BCON
[ 26.028709] dwc3 fe300000.dwc3: do_a_wait_bconn():
[ 26.028714] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 1000
[ 26.114836] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0206e1
[ 26.122898] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x10101
[ 26.129443] xhci-hcd xhci-hcd.0.auto: clear port connect change, actual port 0 status = 0xa0006e1
[ 26.138371] usb usb1-port1: status 0101, change 0001, 12 Mb/s
[ 26.144087] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006e1
[ 26.152150] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x101
[ 26.192594] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006e1
[ 26.200602] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x101
[ 26.208583] xhci-hcd xhci-hcd.0.auto: xhci_hub_status_data: stopping port polling.
[ 26.240591] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006e1
[ 26.248594] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x101
[ 26.288651] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006e1
[ 26.296656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x101
[ 26.336653] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006e1
[ 26.344664] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x101
[ 26.351020] usb usb1-port1: debounce total 100ms stable 100ms status 0x101
[ 26.357873] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 26.362926] xhci-hcd xhci-hcd.0.auto: Slot 1 output ctx = 0x2806b000 (dma)
[ 26.369747] xhci-hcd xhci-hcd.0.auto: Slot 1 input ctx = 0x2806c000 (dma)
[ 26.376538] xhci-hcd xhci-hcd.0.auto: Set slot id 1 dcbaa entry ffffff8009515008 to 0x2806b000
[ 26.385104] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 26.460595] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 26.468606] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 26.474961] usb usb1-port1: not reset yet, waiting 60ms
[ 26.544598] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 26.552602] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 26.558956] usb usb1-port1: not reset yet, waiting 200ms
[ 26.768596] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 26.776599] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 26.782951] usb usb1-port1: not reset yet, waiting 200ms
[ 26.992650] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 27.000656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 27.007009] usb usb1-port1: not reset yet, waiting 200ms
[ 27.052602] dwc3 fe300000.dwc3: otg_main_thread(): OTG_STATE_A_HOST
[ 27.058794] dwc3 fe300000.dwc3: stop_peripheral():
[ 27.063655] dwc3 fe300000.dwc3: stop_peripheral(): INFO: Peripheral already stopped
[ 27.071290] dwc3 fe300000.dwc3: do_a_host():
[ 27.075631] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 27.216592] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 27.224599] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 27.231020] usb usb1-port1: not reset yet, waiting 200ms
[ 27.236255] hub 1-0:1.0: port_wait_reset: err = -16
[ 27.241117] usb usb1-port1: not enabled, trying reset again...
[ 27.246931] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 27.460648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 27.468655] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 27.475010] usb usb1-port1: not reset yet, waiting 200ms
[ 27.684648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 27.692651] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 27.699011] usb usb1-port1: not reset yet, waiting 200ms
[ 27.908589] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 27.916595] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 27.922949] usb usb1-port1: not reset yet, waiting 200ms
[ 28.132647] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 28.140652] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 28.147007] usb usb1-port1: not reset yet, waiting 200ms
[ 28.152288] hub 1-0:1.0: port_wait_reset: err = -16
[ 28.157150] usb usb1-port1: not enabled, trying reset again...
[ 28.162966] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 28.376649] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 28.384656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 28.391008] usb usb1-port1: not reset yet, waiting 200ms
[ 28.600648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 28.608652] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 28.615006] usb usb1-port1: not reset yet, waiting 200ms
[ 28.824596] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 28.832607] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 28.838963] usb usb1-port1: not reset yet, waiting 200ms
[ 29.048663] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 29.056671] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 29.063031] usb usb1-port1: not reset yet, waiting 200ms
[ 29.068305] hub 1-0:1.0: port_wait_reset: err = -16
[ 29.073168] usb usb1-port1: not enabled, trying reset again...
[ 29.078983] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 29.292648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 29.300656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 29.307011] usb usb1-port1: not reset yet, waiting 200ms
[ 29.516648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 29.524652] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 29.531005] usb usb1-port1: not reset yet, waiting 200ms
[ 29.740653] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 29.748657] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 29.755013] usb usb1-port1: not reset yet, waiting 200ms
[ 29.964594] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 29.972600] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 29.978954] usb usb1-port1: not reset yet, waiting 200ms
[ 29.984235] hub 1-0:1.0: port_wait_reset: err = -16
[ 29.989098] usb usb1-port1: not enabled, trying reset again...
[ 29.994916] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 30.208652] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 30.216656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 30.223010] usb usb1-port1: not reset yet, waiting 200ms
[ 30.432648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 30.440652] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 30.447096] usb usb1-port1: not reset yet, waiting 200ms
[ 30.656649] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 30.664657] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 30.671097] usb usb1-port1: not reset yet, waiting 200ms
[ 30.880597] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 30.888601] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 30.895044] usb usb1-port1: not reset yet, waiting 200ms
[ 30.900280] hub 1-0:1.0: port_wait_reset: err = -16
[ 30.905143] usb usb1-port1: not enabled, trying reset again...
[ 30.910956] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 30.917473] xhci-hcd xhci-hcd.0.auto: Broken Port Enabled/Disabled, ignoring port disable request.
[ 30.926424] xhci-hcd xhci-hcd.0.auto: Endpoint 0x0 ep reset callback called
[ 30.933372] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 30.938223] xhci-hcd xhci-hcd.0.auto: Bad real port.
[ 30.943160] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 30.948028] xhci-hcd xhci-hcd.0.auto: Slot 1 output ctx = 0x2806c000 (dma)
[ 30.954879] xhci-hcd xhci-hcd.0.auto: Slot 1 input ctx = 0x2806b000 (dma)
[ 30.961658] xhci-hcd xhci-hcd.0.auto: Set slot id 1 dcbaa entry ffffff8009515008 to 0x2806c000
[ 30.970259] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 31.044649] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 31.052653] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 31.059008] usb usb1-port1: not reset yet, waiting 60ms
[ 31.128594] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 31.136597] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 31.142948] usb usb1-port1: not reset yet, waiting 200ms
[ 31.352592] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 31.360602] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 31.366955] usb usb1-port1: not reset yet, waiting 200ms
[ 31.576648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 31.584659] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 31.591014] usb usb1-port1: not reset yet, waiting 200ms
[ 31.800594] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 31.808603] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 31.814960] usb usb1-port1: not reset yet, waiting 200ms
[ 31.820237] hub 1-0:1.0: port_wait_reset: err = -16
[ 31.825103] usb usb1-port1: not enabled, trying reset again...
[ 31.830918] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 32.044599] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 32.052607] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 32.058960] usb usb1-port1: not reset yet, waiting 200ms
[ 32.268597] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 32.276603] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 32.282955] usb usb1-port1: not reset yet, waiting 200ms
[ 32.492648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 32.500660] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 32.507013] usb usb1-port1: not reset yet, waiting 200ms
[ 32.716648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 32.724655] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 32.731097] usb usb1-port1: not reset yet, waiting 200ms
[ 32.736334] hub 1-0:1.0: port_wait_reset: err = -16
[ 32.741196] usb usb1-port1: not enabled, trying reset again...
[ 32.747012] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 32.960653] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 32.968659] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 32.975014] usb usb1-port1: not reset yet, waiting 200ms
[ 33.184596] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 33.192603] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 33.199042] usb usb1-port1: not reset yet, waiting 200ms
[ 33.408649] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 33.416660] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 33.423100] usb usb1-port1: not reset yet, waiting 200ms
[ 33.632648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 33.640656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 33.647094] usb usb1-port1: not reset yet, waiting 200ms
[ 33.652327] hub 1-0:1.0: port_wait_reset: err = -16
[ 33.657188] usb usb1-port1: not enabled, trying reset again...
[ 33.663005] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 33.876648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 33.884659] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 33.891014] usb usb1-port1: not reset yet, waiting 200ms
[ 34.100648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 34.108656] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 34.115099] usb usb1-port1: not reset yet, waiting 200ms
[ 34.324589] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 34.332599] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 34.339053] usb usb1-port1: not reset yet, waiting 200ms
[ 34.548593] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 34.556604] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 34.563039] usb usb1-port1: not reset yet, waiting 200ms
[ 34.568275] hub 1-0:1.0: port_wait_reset: err = -16
[ 34.573137] usb usb1-port1: not enabled, trying reset again...
[ 34.578952] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 34.792648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 34.800651] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 34.807009] usb usb1-port1: not reset yet, waiting 200ms
[ 35.016602] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 35.024617] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 35.031067] usb usb1-port1: not reset yet, waiting 200ms
[ 35.240650] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 35.248661] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 35.255101] usb usb1-port1: not reset yet, waiting 200ms
[ 35.464652] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 35.472657] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x111
[ 35.479119] usb usb1-port1: not reset yet, waiting 200ms
[ 35.484354] hub 1-0:1.0: port_wait_reset: err = -16
[ 35.489215] usb usb1-port1: not enabled, trying reset again...
[ 35.495027] usb usb1-port1: Cannot enable. Maybe the USB cable is bad?
[ 35.501546] xhci-hcd xhci-hcd.0.auto: Broken Port Enabled/Disabled, ignoring port disable request.
[ 35.510496] xhci-hcd xhci-hcd.0.auto: Endpoint 0x0 ep reset callback called
[ 35.517443] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 35.522294] xhci-hcd xhci-hcd.0.auto: Bad real port.
[ 35.527232] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 35.532101] xhci-hcd xhci-hcd.0.auto: Slot 1 output ctx = 0x2806c000 (dma)
[ 35.538951] xhci-hcd xhci-hcd.0.auto: Slot 1 input ctx = 0x2806b000 (dma)
[ 35.545730] xhci-hcd xhci-hcd.0.auto: Set slot id 1 dcbaa entry ffffff8009515008 to 0x2806c000
[ 35.554331] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xa0006f1
[ 35.628648] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xa0006f1
[ 78.828610] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 130.028606] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 181.228605] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 232.428606] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 283.628686] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
INIT: Id "GS0" respawning too fast: disabled for 5 minutes
[ 334.828610] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 386.028604] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 437.228604] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 488.428604] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 494.864589] xhci-hcd xhci-hcd.0.auto: Port Status Change Event for port 1
[ 494.871309] xhci-hcd xhci-hcd.0.auto: resume root hub
[ 494.876337] xhci-hcd xhci-hcd.0.auto: handle_port_status: starting port polling.
[ 494.883844] usb usb1: usb wakeup-resume
[ 494.887618] usb usb1: usb auto-resume
[ 494.891263] hub 1-0:1.0: hub_resume
[ 494.894735] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0x200e03
[ 494.902704] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x100503
[ 494.909329] usb usb1-port1: status 0503 change 0010
[ 494.914171] xhci-hcd xhci-hcd.0.auto: Broken Port Enabled/Disabled, ignoring port disable request.
[ 494.923131] xhci-hcd xhci-hcd.0.auto: clear port reset change, actual port 0 status = 0xe03
[ 494.931531] xhci-hcd xhci-hcd.0.auto: xhci_hub_status_data: stopping port polling.
[ 495.044610] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[ 495.050025] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0xe03
[ 495.057737] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x503
[ 495.064112] usb usb1-port1: status 0503, change 0000, 480 Mb/s
[ 495.069905] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 495.074776] xhci-hcd xhci-hcd.0.auto: Slot 1 output ctx = 0x2806c000 (dma)
[ 495.081615] xhci-hcd xhci-hcd.0.auto: Slot 1 input ctx = 0x2806b000 (dma)
[ 495.088394] xhci-hcd xhci-hcd.0.auto: Set slot id 1 dcbaa entry ffffff8009515008 to 0x2806c000
[ 495.096996] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xef1
[ 495.147266] xhci-hcd xhci-hcd.0.auto: Port Status Change Event for port 1
[ 495.153973] xhci-hcd xhci-hcd.0.auto: handle_port_status: starting port polling.
[ 495.172593] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0x200e03
[ 495.180516] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x100503
[ 495.187138] xhci-hcd xhci-hcd.0.auto: clear port reset change, actual port 0 status = 0xe03
[ 495.252594] usb 1-1: new high-speed USB device number 6 using xhci-hcd
[ 495.259047] xhci-hcd xhci-hcd.0.auto: Set root hub portnum to 1
[ 495.264948] xhci-hcd xhci-hcd.0.auto: Set fake root hub portnum to 1
[ 495.271278] xhci-hcd xhci-hcd.0.auto: udev->tt = (null)
[ 495.277356] xhci-hcd xhci-hcd.0.auto: udev->ttport = 0x0
[ 495.282650] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 495.287519] xhci-hcd xhci-hcd.0.auto: Successful setup context command
[ 495.294022] xhci-hcd xhci-hcd.0.auto: Op regs DCBAA ptr = 0x00000028064000
[ 495.300879] xhci-hcd xhci-hcd.0.auto: Slot ID 1 dcbaa entry @ffffff8009515008 = 0x0000002806c000
[ 495.309647] xhci-hcd xhci-hcd.0.auto: Output Context DMA address = 0x2806c000
[ 495.316775] xhci-hcd xhci-hcd.0.auto: Internal device address = 0
[ 495.323058] xhci-hcd xhci-hcd.0.auto: Waiting for status stage event
[ 495.329370] xhci-hcd xhci-hcd.0.auto: set port reset, actual port 0 status = 0xef1
[ 495.379691] xhci-hcd xhci-hcd.0.auto: Port Status Change Event for port 1
[ 495.386397] xhci-hcd xhci-hcd.0.auto: handle_port_status: starting port polling.
[ 495.404593] xhci-hcd xhci-hcd.0.auto: get port status, actual port 0 status = 0x200e03
[ 495.412515] xhci-hcd xhci-hcd.0.auto: Get port status returned 0x100503
[ 495.419135] xhci-hcd xhci-hcd.0.auto: clear port reset change, actual port 0 status = 0xe03
[ 495.427545] xhci-hcd xhci-hcd.0.auto: xhci_hub_status_data: stopping port polling.
[ 495.492646] xhci-hcd xhci-hcd.0.auto: Resetting device with slot ID 1
[ 495.499011] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 495.503872] xhci-hcd xhci-hcd.0.auto: Completed reset device command.
[ 495.510302] xhci-hcd xhci-hcd.0.auto: Can't reset device (slot ID 1) in default state
[ 495.518105] xhci-hcd xhci-hcd.0.auto: Not freeing device rings.
[ 495.524010] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 495.528898] xhci-hcd xhci-hcd.0.auto: Successful setup address command
[ 495.535392] xhci-hcd xhci-hcd.0.auto: Op regs DCBAA ptr = 0x00000028064000
[ 495.542239] xhci-hcd xhci-hcd.0.auto: Slot ID 1 dcbaa entry @ffffff8009515008 = 0x0000002806c000
[ 495.551006] xhci-hcd xhci-hcd.0.auto: Output Context DMA address = 0x2806c000
[ 495.558124] xhci-hcd xhci-hcd.0.auto: Internal device address = 0
[ 495.564197] xhci-hcd xhci-hcd.0.auto: Endpoint 0x0 ep reset callback called
[ 495.589453] xhci-hcd xhci-hcd.0.auto: Waiting for status stage event
[ 495.595744] usb 1-1: default language 0x0409
[ 495.600214] xhci-hcd xhci-hcd.0.auto: Waiting for status stage event
[ 495.606703] xhci-hcd xhci-hcd.0.auto: Waiting for status stage event
[ 495.613230] xhci-hcd xhci-hcd.0.auto: Waiting for status stage event
[ 495.619515] usb 1-1: udev 6, busnum 1, minor = 5
[ 495.624105] usb 1-1: New USB device found, idVendor=05dc, idProduct=a81d
[ 495.630791] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 495.637917] usb 1-1: Product: USB Flash Drive
[ 495.642249] usb 1-1: Manufacturer: Lexar
[ 495.646148] usb 1-1: SerialNumber: AARSLQNMKUHE6JZO
[ 495.651266] usb 1-1: usb_probe_device
[ 495.654871] usb 1-1: configuration #1 chosen from 1 choice
[ 495.660332] usb 1-1: ep 0x81 - rounding interval to 128 microframes, ep desc says 255 microframes
[ 495.669363] xhci-hcd xhci-hcd.0.auto: add ep 0x81, slot id 1, new drop flags = 0x0, new add flags = 0x8
[ 495.678699] usb 1-1: ep 0x2 - rounding interval to 128 microframes, ep desc says 255 microframes
[ 495.687542] xhci-hcd xhci-hcd.0.auto: add ep 0x2, slot id 1, new drop flags = 0x0, new add flags = 0x18
[ 495.696863] xhci-hcd xhci-hcd.0.auto: xhci_check_bandwidth called for udev ffffffc025407800
[ 495.705220] xhci-hcd xhci-hcd.0.auto: // Ding dong!
[ 495.710062] xhci-hcd xhci-hcd.0.auto: Successful Endpoint Configure command
[ 495.717003] xhci-hcd xhci-hcd.0.auto: Endpoint 0x81 ep reset callback called
[ 495.724023] xhci-hcd xhci-hcd.0.auto: Endpoint 0x2 ep reset callback called
[ 495.731040] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 495.736773] uas 1-1:1.0: usb_probe_interface
[ 495.740965] uas 1-1:1.0: usb_probe_interface - got id
[ 495.746036] usb-storage 1-1:1.0: usb_probe_interface
[ 495.750953] usb-storage 1-1:1.0: usb_probe_interface - got id
[ 495.756682] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 495.763463] scsi host0: usb-storage 1-1:1.0
[ 495.767721] usb-storage 1-1:1.0: waiting for device to settle before scanning
[ 496.780599] usb-storage 1-1:1.0: starting scan
[ 497.135640] scsi 0:0:0:0: Direct-Access Lexar USB Flash Drive 1100 PQ: 0 ANSI: 4
[ 497.144536] usb-storage 1-1:1.0: scan complete
[ 497.149032] sd 0:0:0:0: [sda] 15656960 512-byte logical blocks: (8.02 GB/7.47 GiB)
[ 497.156860] xhci-hcd xhci-hcd.0.auto: ep 0x81 - asked for 192 bytes, 124 bytes untransferred
[ 497.165219] xhci-hcd xhci-hcd.0.auto: Giveback URB ffffffc0250be100, len = 68, expected = 192, status = 0
[ 497.174810] sd 0:0:0:0: [sda] Write Protect is off
[ 497.179545] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 497.184932] xhci-hcd xhci-hcd.0.auto: ep 0x81 - asked for 192 bytes, 124 bytes untransferred
[ 497.193290] xhci-hcd xhci-hcd.0.auto: Giveback URB ffffffc0250be100, len = 68, expected = 192, status = 0
[ 497.202880] sd 0:0:0:0: [sda] No Caching mode page found
[ 497.208136] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 497.215306] xhci-hcd xhci-hcd.0.auto: ep 0x81 - asked for 192 bytes, 124 bytes untransferred
[ 497.223660] xhci-hcd xhci-hcd.0.auto: Giveback URB ffffffc0252ad600, len = 68, expected = 192, status = 0
[ 497.233556] xhci-hcd xhci-hcd.0.auto: ep 0x81 - asked for 192 bytes, 124 bytes untransferred
[ 497.241914] xhci-hcd xhci-hcd.0.auto: Giveback URB ffffffc025053900, len = 68, expected = 192, status = 0
[ 497.252661] sda: sda1
[ 497.255956] xhci-hcd xhci-hcd.0.auto: ep 0x81 - asked for 192 bytes, 124 bytes untransferred
[ 497.264310] xhci-hcd xhci-hcd.0.auto: Giveback URB ffffffc0252ada00, len = 68, expected = 192, status = 0
[ 497.274274] xhci-hcd xhci-hcd.0.auto: ep 0x81 - asked for 192 bytes, 124 bytes untransferred
[ 497.282632] xhci-hcd xhci-hcd.0.auto: Giveback URB ffffffc0252ada00, len = 68, expected = 192, status = 0
[ 497.292238] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 497.456090] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 539.628607] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 590.828607] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 642.028607] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 693.228608] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 744.428606] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
[ 795.628607] dwc3 fe300000.dwc3: sleep_until_event(): ... sleeping for 50000
My guess is that there is one problem causing problems with both host & peripheral mode. Do you have any other customers using the First port in USB 3 mode and the second in USB 2 mode ?
For us the peripheral mode worked fine in PL 2017.3, but the Host mode had the same symptom (500s delay). But we can live with only having peripheral mode, except that doesnt work PL 2018.1 for us
Do you see anything wrong from the log ?
/Otto
To anyone else suffering from this problem -
There a bug in Vivado causing the second USB block to not work properly, unless a GT lane is assigned to it.
Xilinx is working on a fix for it so hopefully this will be fixed in 2018.3
Hi Aravind,
I have been trying to bringup the USB in OTG mode in the ZCU102 mode but it is not working as expected. I have a Petalinux 2017.4 build with generated with the ZCU102 BSP provided on the Xilinx website.
The device tree configuration i have is:
usb0: usb0@ff9d0000 {
             status = "okay";
             /delete-property/clocks;
             /delete-property/clock-names;
             clocks = <0x3 0x20>;
             clock-names = "bus_clk";
            dwc3@fe200000 {
                     compatible = "snps,dwc3";
                     status = "okay";
                     dr_mode = "otg";
                     snps,dis_u3_susphy_quirk;
                     /delete-property/phy-names;
                     /delete-property/phys;
                     /delete-property/snps,usb3_lpm_capable;
The Kernel configurations is done from
then:
-->Device Drivers
   -->USB Support
      --> <*>   Suppoert for Host-side USB
      -->           [*]    USB announce new devices
      -->           [*]   OTG Support
      -->        <*>    USB 2.0 OTG FSM Implementation
      -->        <*>   xHCI HCD (USB 3.0) support
      -->             -*-   Generic xHCI driver for a platform device
      -->        <*>   EHCI HCD (USB 2.0) support
      -->             [*]   Root Hub Transaction Translators
      -->             [*]   Improved Transaction Translator sceduling
      -->            <*>  Generic EHCI driver for a platform device
      -->        <*>   USB Mass Storage support
      -->            <*>  USB Attached SCSI
      -->        <*>   DesignWare USB3 DRD Core Support
      -->            [*]   Register ULPI PHY Interface
      -->                   DWC3 Mode Selection (Dual Role mode + OTG)
      -->           <*>   PCIe-based Platforms
      -->           <*>   Generic OF Simple Glue Layer
      -->        <*>   DesignWare USB2 DRD Core Support
      -->                   DWC2 Mode Selection (Dual Role mode)
      -->           <*>   DWC2 PCI
      -->    <*> USB Gadget Support   -->
      -->    <*> USB ULPI PHY Interface support
Running with these configurations and doing the appropriate jumper changes I still cannot make the USB to work on OTG mode.
Can you please guide me what I might be doing wrong?
