unixboy
Zynqmp Ultrascale+ Reset Reason bit works?
Hi there~
I am now working PS-domain only reset and it worked by following set of commands;
# mount -t debugfs debug /sys/kernel/debug
# echo "PM_SYSTEM_SHUTDOWN 1 1" > /sys/kernel/debug/zynqmp-firmware/pm
Yes, it is just asking PMU firmware "please reset me". Then after resetting when I came back to shell mode again, the "PS-only reset" field of the following register wasn't set. Why? How can I differentiate between whether I am from normal power-up booting or software reset? I need to skip PL bitstream download when I came from the PS-only reset....
stephenm
You need to enable this in the SRST_EN register
For example, below I have the system setup to detect a lockstep error and inject a fault to test the PMU_RESET_REASON:
Then upon reset, if I read this in the FSBL. I can seethat this is detected correctly
