Visitor dddolphin
a error occur when i 'make dep'
dddolphin@dddolphin-laptop:~/petalinux/software/uClinux-2.4.x$ make dep
rm -f .depend .hdepend
make _sfdep_arch/microblaze/kernel _sfdep_arch/microblaze/mm _sfdep_arch/microblaze/lib _sfdep_arch/microblaze/xilinx_ocp _sfdep_arch/microblaze/platform/microblaze-auto _sfdep_kernel _sfdep_drivers _sfdep_mmnommu _sfdep_fs _sfdep_net _sfdep_ipc _sfdep_lib _sfdep_crypto _FASTDEP_ALL_SUB_DIRS="arch/microblaze/kernel arch/microblaze/mm arch/microblaze/lib arch/microblaze/xilinx_ocp arch/microblaze/platform/microblaze-auto kernel drivers mmnommu fs net ipc lib crypto"
make[1]: 正在进入目录 `/home/dddolphin/petalinux/software/uClinux-2.4.x'
make -C arch/microblaze/kernel fastdep
make[2]: 正在进入目录 `/home/dddolphin/petalinux/software/uClinux-2.4.x/arch/microblaze/kernel'
/home/dddolphin/petalinux/software/uClinux-2.4.x/scripts/mkdep -D__KERNEL__ -I/home/dddolphin/petalinux/software/uClinux-2.4.x/include  -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -fomit-frame-pointer -O2 -fno-builtin -DNO_MM -DNO_FPU -D__ELF__ -DMAGIC_ROM_PTR  -D__linux__ -I.。/include -mno-xl-soft-mul -mno-xl-soft-div -mxl-barrel-shift -mcpu=v7.10.d   -I/home/dddolphin/petalinux/software/uClinux-2.4.x/arch/microblaze/xilinx_ocp -nostdinc -iwithprefix include -- bug.c crtinit.S entry.S exceptions.c head.S hw_exception_handler.S indirect_pci.c init_microblaze_timer.c intv.S irq.c mach.c mach.h microblaze.c microblaze_defs.c microblaze_intc.c microblaze_ksyms.c microblaze_pci.c microblaze_timer.c pci_auto.c pci.c pci-dma.c process.c procfs.c ptrace.c semaphore.c setup.c signal.c syscalls.c time.c xmbserial.c xmbserial.h > .depend
realpath(.。/include) failed, No such file or directory
make[2]: *** [fastdep] 错误 1
make[2]:正在离开目录 `/home/dddolphin/petalinux/software/uClinux-2.4.x/arch/microblaze/kernel'
make[1]: *** [_sfdep_arch/microblaze/kernel] 错误 2
make[1]:正在离开目录 `/home/dddolphin/petalinux/software/uClinux-2.4.x'
make: *** [dep-files] 错误 2
here is the message!
platform:spartan-3e
uclinux:2.4.x(include in petalinux)
thanks for help~~~~
Re: a error occur when i 'make dep'
You may have better luck with the problem going to a petalogix mailing list as that looks like a really old kernel (2.4) and I don't do any work with Petalogix.
Sorry.
-- John
Visitor dddolphin
thanks john!!
i use the petalinux-dist,when i 'make all',there is another error:
make[2]: 正在进入目录 `/home/dddolphin/petalinux/software/petalinux-dist/vendors/Xilinx/Spartan3E500-RevC'
cc -o mkcramfs -I/home/dddolphin/petalinux/software/petalinux-dist/linux-2.4.x/include /home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c -lz
In file included from /home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:36:
/home/dddolphin/petalinux/software/petalinux-dist/linux-2.4.x/include/linux/cramfs_fs.h:120:2: warning: #warning "__BYTE_ORDER == __LITTLE_ENDIAN"
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:38:18: error: zlib.h: 没有该文件或目录
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c: 在函数‘cramsort’中:
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:157: 警告: 赋值丢弃了指针目标类型的限定
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:158: 警告: 赋值丢弃了指针目标类型的限定
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c: 在函数‘write_superblock’中:
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:398: 错误: ‘Z_NULL’未声明(在此函数内第一次使用)
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:398: 错误: (即使在一个函数内多次出现,每个未声明的标识符在其
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:398: 错误: 所在的函数内也只报告一次。)
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c: 在函数‘main’中:
/home/dddolphin/petalinux/software/petalinux-dist/user/cramfs/mkcramfs.c:670: 错误: ‘Z_NULL’未声明(在此函数内第一次使用)
make[2]: *** [mkcramfs] 错误 1
make[2]:正在离开目录 `/home/dddolphin/petalinux/software/petalinux-dist/vendors/Xilinx/Spartan3E500-RevC'
make[1]: *** [image] 错误 2
make[1]:正在离开目录 `/home/dddolphin/petalinux/software/petalinux-dist/vendors'
make: *** [image] 错误 2
thanks for help~~~
