build Qt APP following the wiki page of Zynq UltraScale MPSoC Base TRD 2017.4 - Design Module 5
Hi all:
I am new to petalinux and Qt.
When I tried to build the video application following the steps of wiki xilinux of Zynq UltraScale MPSoC Base TRD 2017.4 - Design Module 5, I got the following:
[guest@localhost video_qt2]$ export SYSROOT=/home/guest/peta_workshop/rdf0429-zcu102-es2-base-trd-2017-4/apu/petalinux_bsp/build/tmp/sysroots/plnx_aarch64
[guest@localhost video_qt2]$ qmake video_qt2-dm5.pro -r -spec linux-oe-g++
Could not find qmake configuration file linux-oe-g++.
Error processing project file: video_qt2-dm5.pro
What did I miss?
THX ahead, any should be helpful!
Re: build Qt APP following the wiki page of Zynq UltraScale MPSoC Base TRD 2017.4 - Design Module 5
Hi @fujiajun,
Enable packagegroup-petalinux-qt in petalinux-conf -c rootfs. Then create a simple user space application follow UG1144 docs.
If you want to build your own Qt app then I have added Qtwebkit example you can use as reference.
qtwebkitdemo.bb content
# This file is the qtwebkitdemo recipe.
SUMMARY = "Qt5 Webkit demo"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = " \
    file://qtwebkitdemo.cpp \
    file://qtwebkitdemo.pro \
S = "${WORKDIR}"
require recipes-qt/qt5/qt5.inc
# Add dependency packages DEPENDS += "qtbase qtwebkit qtdeclarative icu ruby-native sqlite3 glib-2.0 libxslt qtxmlpatterns" RDEPENDS_${PN} += "qtwebkit-qmlplugins" RDEPENDS_${PN} += "${@bb.utils.contains('PACKAGECONFIG_OPENSSL', 'openssl', 'ca-certificates', '', d)}" do_compile() { oe_runmake } do_install() { install -d ${D}${bindir} install -m 0755 qtwebkitdemo ${D}${bindir} }
qtwebkitdemo.cpp content:
#include <QApplication>
#include <QWebView>
int main(int argc, char** argv) {
    QApplication app(argc, argv);
    QWebView view;
    view.show();
    view.setUrl(QUrl("http://webkit.org/blog-files/webgl/SpinningBox.html"));
    return app.exec();
qtwebkitdemo/pro content:
QT += core gui webkit widgets webkitwidgets
SOURCES += qtwebkitdemo.cpp
Sandeep
should I install Qt first?
Hi @fujiajun,
LICENSE = "MIT"
SRC_URI = " \
S = "${WORKDIR}"
#include <QWebView>
    QWebView view;
    view.show();
    return app.exec();
Sandeep
I follow your example in petalinux 2019.2 but the installer in {bindir} doesn't work.
Is it possible that with version 2019.2 it doesn't work?
how can I investigate the error?
Thanks for your help
Luisa
