compiling the kernel
Hi everyone. I recentlly succeded to compile the kernel for the SP605 board, however, after reinstalling my OS and doing some other things I can no longer compile using the same procedure.
I have uncompressed the initramfs.cpio file into a directory and pointed the CONFIG_INITRAMFS_SOURCE parameter in the .config file to point to it. I have applied the commands (both using sudo and without it) "sudo make ARCH=microblaze mmu_defconfig", "sudo make ARCH=microblaze menuconfig" (configured the platform). I have also generated the Device Tree Source file and placed it in  "../ARCH/microblaze/boot/dts". I also set the environment variable PATH with "  export PATH="/home/arquerc/mb-gnu-tools/microblaze-unknown-linux-gnu/bin":$PATH; " which is where I have the microblaze tools placed.
If I am not forgetting anything I went ahead and ran "sudo make ARCH=microblaze CROSS_COMPILE=mb-linux- simpleImage.xilinx" and I got the following output:
arquerc@arquerc-UBUNTU:~/linux-2.6-xlnx$ sudo make ARCH=microblaze CROSS_COMPILE=mb-linux- simpleImage.system
make: mb-linux-gcc: Command not found
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
  CC      kernel/bounds.s
/bin/sh: mb-linux-gcc: command not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
If I am correct this means that the command mb-linux-gcc can not be found and that would mean that i have incorrectlly set the PATH variable right. However if I time "echo $PATH" the value of the variable is correct....
The most alarming thing is that if i write "mb-linux-gcc" into the shell I don't get the "command not found" message... meaning that the file can actually be located....
I really don't know what to do... I was able to compile using this same procedure without any problems just like a week ago.
Re: compiling the kernel
Please... I really need some help....
Did you try setting the CROSS_COMPILE information within Menuconfig
The tools prefix should be: microblaze-unknown-linux-gnu-
Hence to valiadate the tools are correctly installed try running :
shell$ microblaze-unknown-linux-gnu-gcc
You should get microblaze-unknown-linux-gnu-gcc: no input files
Then retry your build steps.
Hope this helps.
Newbie kid5
Hi!
I have the same problem. Could you tell me, how you solved the problem?
Jose
