desulmelionel
configure qt for petalinux 2018.1( zybo board)
I have been trying to configure qt for petalinux on my host machine in order to build a kit in qtcreator. keep running into the same error.I attached my config error. i have included the qt lib that are available in rootfs. Please any help would be greatly appreciated.
sandeepg
Hi @desulmelionel,
Since you are using petalinux you can follow below steps.
1. Enable Qt packages
$ petalinux-config -c rootfs
---> Petalinux Package Groups
---> packagegroup-petalinux-qt
---> [*] packagegroup-petalinux-qt $ vim project-spec/meta-user/recipes-core/images/petalinux-user-image.bbappend #petalinux-user-image.bbappend content inherit populate_sdk_qt5
2. Now use the Qt5 sysroot from Qt creator to build applications.
3. Export the Qt environment variables
4. Run the Application built using Qt creator.
Sandeep
lizhang86
Hi Sandeepg,
Can you please kindly explain step 2 and 3?
Li
