debug ethernet in both UBoot and Linux(Peta-linux)
Hello, I'm using Zynq Ultrascale+ to interface with an ethernet PHY chip from Micrel(Microchip now). The PHY chip is KSZ9031RNX. I'm using Peta-linux 2017.4 to generate u-boot and image.ub.
KSZ9031RNX can support 10/100/1000Mbps ethernet. It has 4x pairs(A,B,C and D) differential signals to support 1000Mbps.    In my design, only 10BASE-T is used. So, my board only connected the differential pair A and B. The differential pair C and D are not connected on my board.
Now, I tried to boot up the board.
It looks U-Boot has successfully recognized the ethernet PHY. see log below:
Then, The booting process continued to load kernel image. But, the kernel can't find the PHY. See log below:
(Please find the details of the log file in the attachment)
Then, I used a ethernet cable to connect with my laptop. And set the laptop to a fixed IP address: 192.168.100.5.  And set the link speed to 10Mbps with full duplex.
Then, boot the system into U-boot. Then, set the IP address of my board to 192.168.100.8. Then, type the command "ping 192.168.100.5" to ping my laptop. It succeeded. (I also used Wireshark to monitor the communication. It looks ok. )
Then, use my laptop to ping my board as below. But, it failed.
Do you know why the Kernel can not recognize ethernet PHY?
My board can ping my laptop? but, why can't my laptop ping my board?
Do I need to configure KSZ9031 to work in 10Mbps first and How?
Re: debug ethernet in both UBoot and Linux(Peta-linux)
That should be all that's necessary to pull the micrel phys into your kernel build.
Some phy code supports compatible attributes but the micrel code does not appear to do so - you can most likely eliminate the compatible node (AFAICT the string literal "ksz9031" does not appear anywhere in the kernel source tree). Then perhaps compare your u-boot and kernel device trees.
Did you enable the Micrel PHYs in your kernel config?
u-boot doesn't respond to ping.
canyiu show your devicetree?
@smcnutt, I have enabled Micrel's PHY in Kernel configuration. See below. Is there anything else I should enable too?
@stephenm, I added the node for PHY in system-user.dtsi as below. Is it ok?
@smcnutt, Thanks for your reply.
I can find the device trees for Kernel.  Do you know where to find the device tree for u-boot inside peta-linux project?
Visitor skanarek
@softwind555  , Did you find the solution ?
can you share you "user dtsi" and kernel configs ?
Thank you!
