lmtripod
/dev/mmcblk0pl1 not found when boot from 16/32GB TF card
Hi there,
Question : Adding below into system-user.dtsi can solve subject mentioned problem[1]. For 8GB TF card, no modification is needed. How to explain this phenomenon ?
&sdhci1 {
   no-1-8-v;
Setup :
- Hardware, customized MPSOC board
- Toolkit, Ubuntu 16.04, PetaLinux 2017.2.
Description :
8/16/32GB TF cards are tested. /dev/mmcblk0p1 founding result are shown in below table.
    isDtsiModify | 32GB            |  16GB             | 8GB
    No                     Not found        Not found       Found
    Yes                    Found               Found              Found
For each TF card, its parameters are list below :
#Size, brand, model
8GB, Chuanyu, KA17010B | C10
16GB, SanDisk Ultra, HC I | C10
32GB, SanDisk Ultra, HC I | C10 | U1
Reference :
[1] https://forum.trenz-electronic.de/index.php?topic=874.0
Thanks a lot !
