driver tainted and no responding to create_channel
so ,  I am trying to use the driver dma_proxy from
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
I added the node in my device tree:
dma_proxy: dma_proxy@0 {
                compatible = "xlnx,dmaproxy";
                dmas = <&axi_dma_0 0 &axi_dma_0 1>;
                dma-names = "dma_proxy_tx", "dma_proxy_rx";
and I created and compiled the module :
petalinux-create -t modules -n dmaproxy
petalinux-build -c dmaproxy
but then when I insmod it I get :
dmesg:
dmaproxy: loading out-of-tree module taints kernel.
and nothing else, and the channels are not in the /dev
My axidmatest is working , so it means the Hardware is okay ....
not a single drive is working ... I have to be missing something.
/include/ "system-conf.dtsi"
amba_pl: amba_pl {
        #address-cells = <1>;
        #size-cells = <1>;
        compatible = "simple-bus";
        ranges ;
        axi_dma_0: dma@40400000 {
            #dma-cells = <1>;
            clock-names = "s_axi_lite_aclk", "m_axi_sg_aclk", "m_axi_mm2s_aclk", "m_axi_s2mm_aclk";
            clocks = <&clkc 15>, <&clkc 15>, <&clkc 15>, <&clkc 15>;
            compatible = "xlnx,axi-dma-1.00.a";
            interrupt-names = "mm2s_introut", "s2mm_introut";
            interrupt-parent = <&intc>;
            interrupts = <0 29 4 0 30 4>;
            reg = <0x40400000 0x10000>;
            xlnx,addrwidth = <0x40>;
            //xlnx,sg-length-width = <0xe>;
            dma-channel@40400000 {
                compatible = "xlnx,axi-dma-mm2s-channel";
                dma-channels = <0x1>;
                interrupts = <0 29 4>;
                xlnx,datawidth = <0x40>;
                xlnx,device-id = <0x0>;
            dma-channel@40400030 {
                compatible = "xlnx,axi-dma-s2mm-channel";
                interrupts = <0 30 4>;
                xlnx,device-id = <0x1>;
        /*axidmatest_1: axidmatest@1 {
                         compatible ="xlnx,axi-dma-test-1.00.a";
                             &axi_dma_0 1>;
                         dma-names = "axidma0", "axidma1";
Re: driver tainted and no responding to create_channel
I am wondering if my drivers (the ones I took from internet) are failing because of my interruptions , I set the IRQs to 29 and 30, and kernel maps them to
49:          0          0     GIC-0  61 Level     xilinx-dma-controller
50:          0          0     GIC-0  62 Level     xilinx-dma-controller
but axidmatest works (which runs from the Kernel space only).
dma1chan0-dma1c: verifying source buffer...
dma1chan0-dma1c: verifying dest buffer...
dma1chan0-dma1c: #4: No errors with
 49:          5          0     GIC-0  61 Level     xilinx-dma-controller
 50:          5          0     GIC-0  62 Level     xilinx-dma-controller
and the IRQs happens in the axidmatest.
Observer jiv4ik
thank you ! but it is what I am doing right ? since my IRQ are in 61 and 62 , they are : "These have IRQ numbers in the range 61--68, and 84--91."
Observer jiv4ik
Your IRQ are okay in my opinion. What is the problem, I unfortunately can not say. At the moment I myself am trying to build a simple project with axi dma chanal to userspace petalinux. What version of Vivado are you using?
I am trying to do the same thing , I am using vivado 2018.2, and I worked to increase the CMA memory , and the shared one , the axidmatest self test is working , but this drivers are not ... I wonder if it is some mismatch in the device tree / driver ..
Observer jiv4ik
In my project does not work until the dmatest(
I see:
dma1chan0-dma1c: #0: tx test timed out
dma1chan0-dma1c: #1: tx test timed out
dma1chan0-dma1c: #2: tx test timed out
dma1chan0-dma1c: #3: tx test timed out
dma1chan0-dma1c: #4: tx test timed out
 I am using vivado 2018.3.
my bus is 64, the channels have different ids (peta was creating them with the same id), I enabled CMA, edited to 60 MB , and shared CMA too , then I created the axidmatest node in the device tree.
