Visitor piotr_czak
drm error with 2018.3 version
we have upgraded project for zynq-7000 (Xilinx Zynq XC7Z030-2FFG676I SoC) from version 2015.4 to version 2018.3 in vivado and prepared appropriate devicetree and kernel in version 2018.3.
When kernel is booting there is a problem related to the drm (log in attachment).
I have checked files (BOOT.bin, devicetree.dtb) in version 2018.3 with kernel in version 2015.4 and there is no problem with drm, hdmi-out works correctly, so I assume that the hw part is correct.
Could you please help to resolve this issue or share an example project with hdmi-out and adv7511 working with linux in version 2018.3 (based on Xilinx ip cores) ?
Note: We had to modify xilinx_drm_drv.c file as the following:
git diff drivers/gpu/drm/xilinx/xilinx_drm_drv.c
diff --git a/drivers/gpu/drm/xilinx/xilinx_drm_drv.c b/drivers/gpu/drm/xilinx/xilinx_drm_drv.c
index c6d4993736bc..a5058d053b66 100644
--- a/drivers/gpu/drm/xilinx/xilinx_drm_drv.c
+++ b/drivers/gpu/drm/xilinx/xilinx_drm_drv.c
@@ -77,8 +77,8 @@ struct xilinx_video_format_desc {
 static const struct xilinx_video_format_desc xilinx_video_formats[] = {
        { "yuv420", 16, 16, XILINX_VIDEO_FORMAT_YUV420, DRM_FORMAT_YUV420 },
        { "uvy422", 16, 16, XILINX_VIDEO_FORMAT_NONE, DRM_FORMAT_UYVY },
-       { "vuy422", 16, 16, XILINX_VIDEO_FORMAT_YUV422, DRM_FORMAT_VYUY },
        { "yuv422", 16, 16, XILINX_VIDEO_FORMAT_YUV422, DRM_FORMAT_YUYV },
+       { "vuy422", 16, 16, XILINX_VIDEO_FORMAT_YUV422, DRM_FORMAT_VYUY },
        { "yvu422", 16, 16, XILINX_VIDEO_FORMAT_NONE, DRM_FORMAT_YVYU },
        { "yuv444", 24, 24, XILINX_VIDEO_FORMAT_YUV444, DRM_FORMAT_YUV444 },
        { "nv12", 16, 16, XILINX_VIDEO_FORMAT_NONE, DRM_FORMAT_NV12 },
Without this modification DRM does not initialize.
Best Regards,
Piotr
Visitor piotr_czak
Re: drm error with 2018.3 version
Here is a log from booting:
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 43000000.dma: Xilinx AXI VDMA Engine Driver Probed!!
Unhandled fault: imprecise external abort (0x1406) at 0x00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops - BUG: 1406 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.14.0-xilinx-sdx2018.3 #89
Hardware name: Xilinx Zynq Platform
task: ef03f840 task.stack: ef040000
PC is at xilinx_vtc_probe+0xa8/0x144
LR is at devm_ioremap+0x54/0x70
pc : [<c03adc28>]    lr : [<c02f90d4>]    psr: 80000013
sp : ef041de0  ip : 00000000  fp : 00000000
r10: ef16dc00  r9 : ef7f73d0  r8 : 00000000
r7 : 00000000  r6 : ef320c50  r5 : ef16dc10  r4 : f0970000
r3 : 00000000  r2 : 00000000  r1 : a0000013  r0 : f0970000
Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
Control: 18c5387d  Table: 0000404a  DAC: 00000051
Process swapper/0 (pid: 1, stack limit = 0xef040210)
Stack: (0xef041de0 to 0xef042000)
1de0: ef7f73d0 00000000 00000000 c034130c 43c30000 43c3ffff ef7f7428 00000200
1e00: 00000000 00000000 00000000 00000000 ef3daf80 ee8cec10 00000000 ef7f73d0
1e20: ee82f6d0 ee8c5400 ee8ce810 c03aa260 ee8c5400 c0817d9e ee8c5400 ef16dc10
1e40: 00000000 ee82f6d0 c0a18714 ef16dc10 ef16dc00 c03aa930 ef16e9a0 c082bb1b
1e60: ee8cd580 00000000 00000000 c03aa8d4 ef16dc10 c0a18714 00000000 c0a18714
1e80: 00000000 00000000 00000000 c03baa44 ef16dc10 c0a56890 c0a56894 c03b958c
1ea0: ef16dc10 ef16dc44 c0a18714 c0a190c8 00000000 c093cd40 c093383c c03b96cc
1ec0: 00000000 c0a18714 c03b9650 c03b7ddc ef076f58 ef1590b4 c0a18714 ef1f2f80
1ee0: 00000000 c03b8c04 c081897b c081897c 00000000 c0a18714 c0a3c480 c0933834
1f00: c0918f34 c03b9e50 ffffe000 c0a3c480 c0933834 c01019ac c08962b4 00000000
1f20: 00000000 c0132bd0 00000000 c0895238 000000d4 00000006 00000006 c08962c8
1f40: 000000d3 c08962c8 efffed73 00000000 00000000 00000007 c0a3c480 c0933830
1f60: 00000007 c0a3c480 c0933834 000000d4 c0a3c480 c0900da4 00000006 00000006
1f80: 00000000 c090059c 00000000 c06514dc 00000000 00000000 00000000 00000000
1fa0: 00000000 c06514e4 00000000 c0106fb0 00000000 00000000 00000000 00000000
1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 28201040 805c0400
[<c03adc28>] (xilinx_vtc_probe) from [<c03aa260>] (xilinx_drm_crtc_create+0x1e0/0x36c)
[<c03aa260>] (xilinx_drm_crtc_create) from [<c03aa930>] (xilinx_drm_platform_probe+0x5c/0x3bc)
[<c03aa930>] (xilinx_drm_platform_probe) from [<c03baa44>] (platform_drv_probe+0x50/0x9c)
[<c03baa44>] (platform_drv_probe) from [<c03b958c>] (driver_probe_device+0x1ec/0x2b0)
[<c03b958c>] (driver_probe_device) from [<c03b96cc>] (__driver_attach+0x7c/0xa8)
[<c03b96cc>] (__driver_attach) from [<c03b7ddc>] (bus_for_each_dev+0x7c/0x8c)
[<c03b7ddc>] (bus_for_each_dev) from [<c03b8c04>] (bus_add_driver+0x16c/0x1d4)
[<c03b8c04>] (bus_add_driver) from [<c03b9e50>] (driver_register+0xa0/0xe0)
[<c03b9e50>] (driver_register) from [<c01019ac>] (do_one_initcall+0xf8/0x118)
[<c01019ac>] (do_one_initcall) from [<c0900da4>] (kernel_init_freeable+0x188/0x1c8)
[<c0900da4>] (kernel_init_freeable) from [<c06514e4>] (kernel_init+0x8/0x108)
[<c06514e4>] (kernel_init) from [<c0106fb0>] (ret_from_fork+0x14/0x24)
Code: e5860000 8affffe3 e590800c f57ff04f (e3c88c3f)
---[ end trace 7926ad45da104534 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
CPU0: stopping
CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D         4.14.0-xilinx-sdx2018.3 #89
[<c010e764>] (unwind_backtrace) from [<c010a98c>] (show_stack+0x10/0x14)
[<c010a98c>] (show_stack) from [<c06414e8>] (dump_stack+0x80/0xa0)
[<c06414e8>] (dump_stack) from [<c010ceb8>] (ipi_cpu_stop+0x3c/0x70)
[<c010ceb8>] (ipi_cpu_stop) from [<c010d6d8>] (handle_IPI+0x64/0x84)
[<c010d6d8>] (handle_IPI) from [<c0101420>] (gic_handle_irq+0x84/0x90)
[<c0101420>] (gic_handle_irq) from [<c010b3cc>] (__irq_svc+0x6c/0xa8)
Exception stack(0xc0a01f48 to 0xc0a01f90)
1f40:                   00000001 00000000 00000000 c0116640 00000000 00000000
1f60: ffffe000 c0a03c68 c0a03cb4 c0933a30 00000000 00000000 2ee8e000 c0a01f98
1f80: c01079bc c01079ac 60000113 ffffffff
[<c010b3cc>] (__irq_svc) from [<c01079ac>] (arch_cpu_idle+0x1c/0x38)
[<c01079ac>] (arch_cpu_idle) from [<c01494d4>] (do_idle+0xf8/0x1a8)
[<c01494d4>] (do_idle) from [<c01496bc>] (cpu_startup_entry+0x18/0x1c)
[<c01496bc>] (cpu_startup_entry) from [<c0900bbc>] (start_kernel+0x304/0x364)
[<c0900bbc>] (start_kernel) from [<0000807c>] (0x807c)
---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Best Regards,
Piotr
