jinbangchen
edk os setting
 I has falled in trouble and need your help.I want to achieve  linux(not uclinux) transplantation  base on microblaze in spartan 3e board. But in my EDK,i can't find "linux" option  in the os & library setting  which is in the software  platform setting.What should I do  can let the "linux  option"  appear in the os & library setting.  Thanks!!!!
peters
Petalogix has a good documentation on the necessary steps:
http://www.petalogix.com/resources/documentation/petalinux/userguide/Customising/NewHardware
For the OS to show up in the OS&Library setting dialog especially the sections
'create edk_user_repository link' and 'update system.xmp file' are important.
hungbkfet
i have a same problem as you, but now is 2011, if you can slove,please send to me,
my email:dqhungbk@gmail.com
Thank you very much!!!!!
Anonymous
Not applicable
hungbkfet
Thanks for your reply, i can not download from git server, it seem to be down, but i have device-tree bsp folder.
and i do same as your instruction,but now i still not work,
can you show me more,
So sorry abt my English....
