erro execution application on linux 2.6 on a custom board with virtex5
I have ported Linux 2.6  into my custom board with virtex 5 by (with a ramdisk).
to test it, I have use the simple application " hello world " I have cross-compile the application and I  put the execurtable in the  / home in the  Linux distribution.
  I wanted execute (. / hello ). it  puts me the following error : hello not found .
it's not executing .
1. don't use "TAB" for auto completion
2. Don't use ./ just go in home and try hello (will execute and display if u have display(monitor) connected, can't display over serial)
You may have built it with shared libs (dynamically) rather than statically.
If use -static when you build the application you won't have a dependency on the libs.
Too bad I didn't see this earlier, so my posting is kind of redundant. I am wondering what toolchains should be used to create an executable that is suitable for the ramdisk provided by xilinx. The ELDK links against very fat std stuff....
