eth0: unable to generate target frequency: 25000000 Hz
     1. landed into this "unable to targer frequency" error.
     2. looked at earlier posts and confirmed that clk is NOT drawn from EMIO pins [plz check picture attached].
     3. for some reason, i cannot dump this [in other words, this file [clk_summary] is not present].
cat /sys/kernel/debug/clk/clk_summary
      4. logs for the error is in this post
      5. board dont get ip when i do udhcpc
      6. GEM3 interface pins configuration attached with this post.
      7. please let me know if you need anything more.
      8. please help to solve this issue.
root@DNA_fmc:~# udhcpc
udhcpc (v1.24.1) started
Sending discover...
Sending discover...
Sending discover...
[ 49.224908] macb ff0e0000.ethernet eth0: link down
[ 50.228946] macb ff0e0000.ethernet eth0: unable to generate target frequency: 25000000 Hz
[ 50.237056] macb ff0e0000.ethernet eth0: link up (100/Full)
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Sending discover...
Re: eth0: unable to generate target frequency: 25000000 Hz
    i solved this. i acidentally connected to 100M switch and for 100M it requires 25MHz frequency.
now i connected to 1000M [1G] switch and the auto negotiation went with 125MHz frequency, i get the ip now.
Observer trilok_4
Hi ,
I have similar issue, please can you help me out. I'm using Zybo board and Vivado 2016.3. I tried enabling auto-negation and fixing 1G speed in Host machine, but none of the combination worked.  Hoping for response
Thanks/Regards
Trilok
Can you make sure that the ethernet clock is set to 25Mhz in the Vivado project in the Zynq PS config GUI
