s002wjh
ethernet wont connect point to point
running 3.17 kernel, i can establish connection between my PC and 706board via network switch, however if i connect board directly to win7 PC via ethernet port i cant ping the board at all.  I setup a board IP by using ifconfig eth0 someip
is there something i need to do in config menu ?
so after look at the bootup message i see this
under petalinux guide, during bootup
Configuring network interfaces... udhcpc (v1.20.2) started
Sending discover...
xemacps e000b000.ps7-ethernet: Set clk to 124999998 Hz
xemacps e000b000.ps7-ethernet: link up (1000/FULL)
however mine show when connect point to point
Configuring network interfaces... xemacps e000b000.ethernet: eth0: no PHY setup
udhcpc (v1.22.1) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
any ideas?
gszakacs
Professor
Professor
Are you running a DHCP servier on your PC?  If not you may need the network switch for discovery unless you can program the board to use a fixed IP address.
-- Gabor
milosoftware
Try enabling "internet sharing" on your PC, that will initiate a DHCP server.
