Participant sandeepdutta
fpga manager : bitstream loading not working 2018.2
Trying to load bitstream using the FPGA manager in petalinux 2018.2 hangs the whole
system. I followed the instructions at http://www.wiki.xilinx.com/Solution+ZynqMP+PL+Programming
I have a ZCU102 , with an ES2 part.  If I load the same bitstream using JTAG is works fine.
Also if I use petalinux 2017.4 I can use the FPGA manager and follow the same instructions and it works.
Any ideas  ??
Sandeep
Re: fpga manager : bitstream loading not working 2018.2
This issue seems to be with bitstream image format.
The Bootgen Command for generating the bin file from bit got changed from 2018.1 release onwards.
bootgen -image Bitstream.bif -arch zynqmp -o ./Bitstream.bin -w
This info was Documented in the below link (Refer this section: Generating .bin from .bit file using Bootgen)
http://www.wiki.xilinx.com/Solution+ZynqMP+PL+Programming.
Please try with the about  command and let me know your observations.
Can yhiu show the boot log up to the crash,
The system boots normally. I am trying to load the bitstream from the command line.
Here is what I see
root@xilinx-zcu102-zu9-es2-rev1_0-2018_2:~/bits# echo vsi_system_zynqMP_pl_hier_0.bit.bin > /sys/class/fpga_manager/fpga0/firmware
[ 49.981122] fpga_manager fpga0: writing vsi_system_zynqMP_pl_hier_0.bit.bin to Xilinx ZynqMP FPGA Manager
The system freezes at this point. I notice that the "INIT" Led is green , the "Done"  LED remains low. The same command with the same bitstream works fine if I use 2017.4.
Best
Sandeep
Attached boot log for boot 2017.4 (working) & 2018.1 (not working) with the same bitstream.
I tried with the Ultra96 (2018.2) same problem, any solution for this would be appreciated.
sandeep
Voyager
Voyager
Hi @sandeepdutta,
Try with cat command :
# cat vsi_system_zynqMP_pl_hier_0.bit.bin > /dev/xdevcfg
Not sure because i'm on Zynq and not ZynMP :S
[EDIT]: After some tests on a custom board base on Zynq7000 echo commande doesn't work ...
[ 5594.037260] Did not transfer last 3 bytes
Maybe you should also take a look to bit/bin format ... Maybe ... Maybe not :S
Cheers,
Trigger
Thank you Trigger, unfortunately /dev/xdevcfg has been deprecated
Could you please share the bit file and top level vivado block diagram if possible??
Thank you Navam,
That was the problem...
Best Regards
Sandeep
Participant eengie
I realize this was nearly a year ago, but today the command shown on that wiki is: bootgen -image file.bif -arch zynqmp -process_bitstream bin.  And it doesn't work for me.  Several seconds after attempting to write the resulting image to the manager, the kernel panics.  If I use the command provided above in this forum, the resulting image writes immediately to the FPGA without issues.  (Vivado 2018.3)
