fsck: fsck.auto: No such file or directory
I am trying to install fsck in order to repair the FS
I found Install fsck
but I get an error fsck: fsck.auto: No such file or directory;
Borad Type :The board is Zynq UltraScale+ MPSoC.
Any Idea?
No problem thanks for your help  and guide
fsck.auto is a helper that determines the type of filesystem, and then calls a filesystem-specific checker. This is a convenience, but it is not actually necessary, if you know the type of filesystem.
eg. it may be FAT or VFAT for older DOS filesystem, NTFS for newer windows formatted partition, or it may be ext2/3/4 for a linux rootfilesystem. There are others of course.
For each there is a specific checker that you can call directly. Here are some possible examples:
fsck.vfat /dev/mmcblk0p1
fsck.ext4 /dev/mmcblk0p2
I don't have the commands you wrote  ; this is the reason I am trying to use fsck
Well, fsck (and fsck.auto) will eventually call the utilities I mentioned. So you'll need them one way or the other.
The fsck utility itself can be enabled with "petalinux -c rootfs" then Filesystem Packages --> base --> util-linux --> util-linux-fsck. I guess you have this, and it's the the one giving you the error about "fsck.auto missing".
The fsck.ext2 / fsck.ext3 / fsck.ext4 are part of the e2fsprogs-e2fsck package. Run "petalinux -c rootfs" and check in Filesystem Packages --> base --> e2fsprogs --> e2fsprogs-e2fsck
The ones for FAT/VFAT come from the dosfstools package... which for some reason does not seem to be in Petalinux (perhaps I missed it, or it is under a different name).
thanks for the reply no fsck.vfat to check my FS
fsck fsck.ext2 fsck.ext3 fsck.ext4 fsck.util-linux
Right, for vfat you need to add the dosfstools package. I've not tried it, but there is an older post about this:
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-fsck-support-for-FAT32-file-systems/td-p/860481
Again thanks for the reply
In my first message I had a link you posted and it didn't work.
Oh, we've gone full circle
By "didn't work" do you mean: did you get an error building it? Or did it seem to succeed, but there was no fsck.vfat produced?
Also, which version of Petalinux are you using, might help so we can try and reproduce...
No: fsck.vfat , when install the image.
I am using 2018.2
Seems that 2018.x version is not compatible with ubuntu 18.04.x (there are a lot of posts about this) so unfortunately I cannot easily reproduce this...
