04-24-2020 08:05 AM
Hi everyone,
I'm building a project with a dependency on grpc (or will have). I want to export the protobuf compiler (protoc) and the grpc code generator pugins into the native sdk, so I can use the tools inside the 2019.1 xsdk (yes, I'm going to migrate to Vitis once 2020.1 in released).
I have added grpc as depdency in my own application recipe, which contains the following statement.
DEPENDS += "grpc grpc-native"
Furthermore I have added the following lines to petalinuxbsp.conf:
TOOLCHAIN_HOST_TASK_append = " nativesdk-protobuf-compiler" TOOLCHAIN_HOST_TASK_append = " nativesdk-grpc"
I can build my project, and export the SDK. I can see all libraries (including grpc) in the SDK, except the grpc-plugin.
sdk/sysroots/x86_64-petalinux-linux$ find . -name "protoc" ./usr/bin/protoc sdk/sysroots/x86_64-petalinux-linux$ find . -name "grpc_cpp_plugin" sdk/sysroots/x86_64-petalinux-linux$
Any idea how I can this plugin into the native sdk? There is an arm version built, which I have no use for.
sdk/sysroots/cortexa9t2hf-neon-xilinx-linux-gnueabi$ find . -name "grpc_cpp_plugin" ./usr/bin/.debug/grpc_cpp_plugin ./usr/bin/grpc_cpp_plugin sdk/sysroots/cortexa9t2hf-neon-xilinx-linux-gnueabi$
Now I'm still a bit of a noob with Yocto/OpenEmbedded and bitbake, so maybe I'm missing something obvious. Any pointers how to get the grpc plugin into the native part of the SDK? Thanks!
Cheers,
Vincent
09-25-2020 11:45 AM
Any reply on this thread?
