gcc for petalinux
Hello everyone,
i want to compile a cpp-application on petalinux. But there is no gcc or g++. And if i want to install it via apt-get install, there is no apt.
Is there a tutorial existing, how to compile the application code?
Hi @williamti
Please export the toolchain & build.
For reference plese follow below steps:
export PATH=$PATH:/proj/petalinux/petalinux-v2018.2_daily_latest/petalinux-v2018.2-final/tools/linux-i386/aarch64-linux-gnu/bin/
export ARCH=arm64
export CROSS_COMPILE=aarch64-linux-gnu-
aarch64-linux-gnu-gcc app.c
Thanks & Regards
Aravind
