vinay@vayavya
generating PWM signal using AXI timer in linux
        I'm using microzed board which has zynq (XC7Z020) SOC to drive a motor, I'm able to boot the board with Linux  4.6.0 kernel.
But is there any driver for AXI-timer in Linux? How can I make the AXI-timer work in PWM mode?
The link below shows the boot log snippet for AXI-timer, But I didn't get any such lines in the boot log.
http://www.wiki.xilinx.com/Axi+timer
Can anybody tell me how can I use AXI - timer to generate PWM signal in Linux environment?
Thanks in advance.
jasons313
I am running into a similar problem.  Out of curiosity, are you using the Petalinux SDK (what version?) or the Yocto workflow?
What I found in Petalinux 2015.2 at least, was the DTS generated showed this:
axi_timer_0: timer@42800000 {
compatible = "xlnx,xps-timer-1.00.a";
But... there are no drivers in the petalinux package that are compatible with xlnx,xps-timer-1.00.a (except for microblaze arch)
I haven't tried it yet, but I was going to patch the petalinux package with this driver:
https://github.com/btanghe/xilinx-pwm
Assuming this is your problem you might want to try as well
