kevinwang65
got errors during petalinux-build
 I got errors during petalinux-build as follows, please help.
$ petalinux-build
INFO: Sourcing build tools
[INFO] Building project
[INFO] Sourcing build environment
[INFO] Generating workspace directory
INFO: bitbake petalinux-image-minimal
WARNING: /home/kevin/xilini-ultra96/ultra96v2/project-spec/meta-avnet/recipes-apps/pmic-prog/pmic-prog.bb: Exception during build_dependencies for AUTOREV
WARNING: /home/kevin/xilini-ultra96/ultra96v2/project-spec/meta-avnet/recipes-apps/pmic-prog/pmic-prog.bb: Error during finalise of /home/kevin/xilini-ultra96/ultra96v2/project-spec/meta-avnet/recipes-apps/pmic-prog/pmic-prog.bb
ERROR: ExpansionError during parsing /home/kevin/xilini-ultra96/ultra96v2/project-spec/meta-avnet/recipes-apps/pmic-prog/pmic-prog.bb
hokim
Did you enable BB_NO_NETWORK?
Yocto manual says:
The offline build does not work if recipes attempt to find the latest version of software by setting SRCREV to ${AUTOREV}
https://docs.yoctoproject.org/gatesgarth/dev-manual/dev-manual-common-tasks.html#replicating-a-build-offline
Use the latest commit hash instead of AUTOREV
$ vi pmic-prog.bb
#SRCREV = "${AUTOREV}"
SRCREV = "ce8fcca99540a07ed60400fc9b218d843d0de8b7"
kevinwang65
Where is the location of pmic-prog.bb? Thanks.
hokim
See your log
stephenm
Can you share this BB file:
There is an error in this file.
kevinwang65
Here is the bb file.
kevinwang65
I modified .bb file to
but still got errors.
stephenm
I dont see the bb file. As per the error message the tools are struggling to parse this file.
kevinwang65
re-send the .bb file.
kevinwang65
here is the error message.
hokim
Your log says:
git -c core.fsyncobjectfiles=0 ls-remote https://github.com/Avnet/BSP-rootfs-sources.git failed with exit code 128, output:
fatal: unable to access 'https://github.com/Avnet/BSP-rootfs-sources.git/': SSL certificate problem: unable to get local issuer certificate
In linux terminal, could you try this?
$ cd <peta-proj-dir>
$ ./build/tmp/hosttools/git -c core.fsyncobjectfiles=0 ls-remote https://github.com/Avnet/BSP-rootfs-sources.git
To fix it , refer to https://confluence.atlassian.com/bitbucketserverkb/ssl-certificate-problem-unable-to-get-local-issuer-certificate-816521128.html
kevinwang65
 I ran it again from my home and error massage has been changed. Here is the log file.
ERROR: device-tree-xilinx-v2020.2+gitAUTOINC+f725aaecff-r0 do_compile: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:devicetree_do_compile(d)
0003:
File: '/home/kevin/xilini-ultra96/ultra96v2/components/yocto/layers/core/meta/classes/devicetree.bbclass', lineno: 124, function: devicetree_do_compile
0120:
0121:python devicetree_do_compile() {
0122: includes = expand_includes("DT_INCLUDE", d)
0123: listpath = d.getVar("DT_FILES_PATH")
*** 0124: for dts in os.listdir(listpath):
0125: dtspath = os.path.join(listpath, dts)
0126: try:
0127: if not(os.path.isfile(dtspath)) or not(dts.endswith(".dts") or devicetree_source_is_overlay(dtspath)):
0128: continue # skip non-.dts files and non-overlay files
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/kevin/xilini-ultra96/ultra96v2/project-spec/configs/../../components/plnx_workspace/device-tree/device-tree'
ERROR: Logfile of failure stored in: /home/kevin/xilini-ultra96/ultra96v2/build/tmp/work/u96v2_sbc-xilinx-linux/device-tree/xilinx-v2020.2+gitAUTOINC+f725aaecff-r0/temp/log.do_compile.15032
NOTE: recipe device-tree-xilinx-v2020.2+gitAUTOINC+f725aaecff-r0: task do_compile: Failed
ERROR: Task (/home/kevin/xilini-ultra96/ultra96v2/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2166 tasks of which 2005 didn't need to be rerun and 1 failed.
ERROR: Failed to build project
