wzhang1
how to disable L2 cache on APU of ZCU102
I like to compare the performance on the APU of ZCU102 production board with L2 cache enabled and disabled.
I am assuming L2 cache is enabled by default on APU. (Correct me if I am wrong.) Then the question is how to disable L2 cache. I am even not sure if this is possible or not.
After some research, it looks like to me that it is possible to remove L2 cache in the device-tree. But I couldn't find the corresponding node there.
Thanks!
sandeepg
Hi @wzhang1,
Yes you can disable only if the device-tree entry for CPU has this properties https://www.devicetree.org/downloads/devicetree-specification-v0.1-20160524.pdf or else you can't.
AFAIK we don't have these properties in device-tree.
Sandeep
sandeepg
Someone had already done for Zynq7000 https://secbus.telecom-paristech.fr/wiki/DisablingZynqCaches
Sandeep
wzhang1
Thank you very much for your reply, Sandeep!
I searched for device tree configuration in my petalinux project. No L2 cache entry was found.
However, I found the following stuff under the folder of "project-spec".
1. in ./meta-plnx-generated/recipes-bsp/u-boot/configs/config.cfg:
CONFIG_SYS_L2CACHE_OFF is not set
What is CONFIG_SYS_L2CHACHE_OFF for? Is it for turning ON/OFF L2 cache on APU?
2. in ./configs/rootfs_config:
CONFIG_ccache is not set
CONFIG_ccache-dbg is not set
CONFIG_ccache-dev is not set
CONFIG_udev-cache is not set
CONFIG_menu-cache is not set
CONFIG_menu-cache-dbg is not set
CONFIG_menu-cache-dev is not set
What are these options for? Would you please give me some information about them?
Thanks!
Wei
sonminh
Hi @wzhang1 , @sandeepg ,
I'm need to disable cache on zc706 run petalinux.
have you try disable cache ?
Can you heclp me?
sandeepg
Hi @sonminh ,
Take a look on this wiki https://gitlab.telecom-paris.fr/renaud.pacalet/secbus/wikis/disabling-zynq-caches
Sandeep
sonminh
I just try implement as you talk but no have any change once boot petalinux 2017.4 on zc706:
1. In file xilinx_zynq_defconfig of external linux  (components/ext_sources/linux-xlnx-2017.4_video_ea/arch/arm/configs), I add in to end of file:
CONFIG_CPU_ICACHE_DISABLE=y
CONFIG_CPU_DCACHE_DISABLE=y
2. petalinux-config -c kernel --defconfig xilinx_zynq_defconfig
3. petalinux-build -c kernel
4. Modify file system-user.dtsi in /project-spec/meta-user/recipes-bsp/device-tree/files:
/include/ "system-conf.dtsi"
&amba {
cache-controller@f8f02000 {
status = "disabled";
5. Petalinux-build
This is my device-tree after disable cache and build:
compatible = "arm,pl310-cache";
reg = <0xf8f02000 0x1000>;
interrupts = <0x0 0x2 0x4>;
arm,data-latency = <0x3 0x2 0x2>;
arm,tag-latency = <0x2 0x2 0x2>;
cache-unified;
cache-level = <0x2>;
But once boot with BOOT.bin and image.ub just build, L2 cache still enable and I don't know veryfy that L1 is disabled. I see time to boot still fast. Here is console once boot linux, L2 cache still probe although disable.
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 4.9.0-xilinx (thanhnt@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Sat Nov 16 14:11:29 +07 2019
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5287d
OF: fdt:Machine model: Zynq ZC706 Development Board
bootconsole [earlycon0] enabled
cma: Reserved 16 MiB at 0x3f000000
Memory policy: Data cache writealloc
percpu: Embedded 14 pages/cpu @ef7cb000 s25932 r8192 d23220 u57344
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Kernel command line: console=ttyPS0,115200 earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1007240K/1048576K available (6144K kernel code, 200K rwdata, 1464K rodata, 1024K init, 230K bss, 24952K reserved, 16384K cma-reserved, 245760K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0700000   (7136 kB)
      .init : 0xc0900000 - 0xc0a00000   (1024 kB)
      .data : 0xc0a00000 - 0xc0a32180   ( 201 kB)
       .bss : 0xc0a32180 - 0xc0a6b998   ( 231 kB)
        Build-time adjustment of leaf fanout to 32.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to f0802000
slcr mapped to f0804000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0804100
Zynq clock init
Can you talk clearly? Thank you
