08-03-2017 12:07 AM
Hi Xilinx,
petalinux 2015.4, zedboard
I have connected a UIO Spi Pmod device, adding a node in the system-top.dts
amba_pl {
Pmod@80000000 {
compatible = "generic-uio";
UIO does not specify num-transfer-bits, max-frequency, spi-mode etc as defined in the spidev as shown in the following example:
https://forums.xilinx.com/t5/Embedded-Linux/How-to-use-XPS-SPI-core-driver-in-linux/td-p/73313
xps_spi_1: xps-spi@f6000080 {
compatible = "xlnx,xps-spi-2.00.b", "xlnx,xps-spi-2.00.a";
#address-cells=<1>;
#size-cells=<0>;
interrupt-parent = <&xps_intc_0>;
interrupts = < 7 2 >;
reg = < 0xf6000080 0x80 >;
xlnx,family = "virtex5";
xlnx,fifo-exist = <0x1>;
xlnx,num-ss-bits = <0x2>;
xlnx,num-transfer-bits = <0x8>;
xlnx,sck-ratio = <0x20>;
device@0 {
compatible = "spidev";
reg = <0>; //Chip select 0
spi-max-frequency = <3125000>;
Therefore, I tried to directly write to SPI Control Register (SPICR) 0x60. follow https://www.xilinx.com/support/documentation/ip_documentation/axi_quad_spi/v3_2/pg153-axi-quad-spi.pdf
Still I find no way to define num-transfer-bits, max-frequency, and I guess my UIO-SPI is running @ default mode now, which make data transfer very slow, therefore I have to add delay function after each byte transfer to wait previous transfer settled.
Please advise how to properly configure a UIO-SPI . Thanks in advance.
Mike
08-05-2017 11:27 PM
08-03-2017 05:15 AM
why don't you use "spidev" instead of "generic-uio"?
08-05-2017 11:27 PM
