evan
i want to save data after QSPI boot
Hello
I succeeded in booting linux using QSPI flash on a custom board created using ZynqMP.
I think it took more than a month, but it was too difficult.
I entered (ID: root PW: root) and checked a simple linux command.
ex. ls, pwd, mkdir etc..
However, if I create a file using mkdir and reboot, the file I created is missing. It seems to be initialized.
Here is the question!! >> Do you know how to solve this?
Here is what I set in petalinux.
>> Subsystem AUTO Hardware Settings -> Advanced bootable images storage Settings -> boot image settings -> primary flash
>> Subsystem AUTO Hardware Settings -> Advanced bootable images storage Settings -> boot image settings -> primary sd
>> Image Packaging Configuration -> INITRAMFS
* When QSPI flash is included with image.ub, an error occurs with a warning message (ERROR: can't get kernel image! ). -> If you know why, please let me know.
Next is Boot_Log.
Release 2019.1   Jul 22 2020  -  05:13:09
PMU Firmware 2019.1     Jul 22 2020   05:13:54
PMU_ROM Version: xpbr-v8.1.0-0
NOTICE:  ATF running on XCZU19EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE:  BL31: Secure code at 0x0
NOTICE:  BL31: Non secure code at 0x8000000
NOTICE:  BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790
NOTICE:  BL31: Built : 06:59:32, Jul 22 2020
PMUFW:  v1.1
U-Boot 2019.01 (Jul 22 2020 - 06:58:22 +0000)
Board: Xilinx ZynqMP
DRAM:  1023 MiB
EL Level:       EL2
Chip ID:        zu19eg
MMC:   mmc@ff170000: 0
Loading Environment from SPI Flash... SF: Detected mt25qu02g with page size 512
Bytes, erase size 128 KiB, total 512 MiB
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Bootmode: QSPI_MODE
Reset reason:   SRST
Net:   ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for hydra_linux
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete.... done
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.0.21 (270 ms)
Hit any key to stop autoboot:  0
Device: mmc@ff170000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
24745128 bytes read in 1765 ms (13.4 MiB/s)
   Using 'conf@system-top.dtb' configuration
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x10000104
     Data Size:    18082304 Bytes = 17.2 MiB
     Architecture: AArch64
     OS:           Linux
     Load Address: 0x00080000
     Entry Point:  0x00080000
     Hash algo:    sha1
     Hash value:   ad43daa81559da4b0ebfdbc333cc88af0663bc84
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Compression:  gzip compressed
     Data Start:   0x111466e8
     Data Size:    6629423 Bytes = 6.3 MiB
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   3a570281290127f8622409d0500f4265bcda2bb0
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x1113ec08
     Data Size:    31260 Bytes = 30.5 KiB
     Hash algo:    sha1
     Hash value:   1b5d814c0081b8c0ca112276d4f8af8ba341ce04
   Booting using the fdt blob at 0x1113ec08
   Loading Kernel Image ... OK
   Loading Ramdisk to 079ad000, end 07fff82f ... OK
   Loading Device Tree to 00000000079a2000, end 00000000079aca1b ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc versio
n 8.2.0 (GCC)) #1 SMP Wed Jul 22 04:57:56 UTC 2020
[    0.000000] Machine model: xlnx,zynqmp
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x000000002fc00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with
crng_init=0
[    0.000000] percpu: Embedded 23 pages/cpu @(____ptrval____) s53656 r8192 d323
60 u94208
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 258307
[    0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_un
used
[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Memory: 744476K/1047552K available (10748K kernel code, 634K rwda
ta, 5420K rodata, 832K init, 314K bss, 40932K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:
0x171015c90f, max_idle_ns: 440795203080 ns
[    0.000004] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 43980
46511101ns
[    0.008265] Console: colour dummy device 80x25
[    0.012402] Calibrating delay loop (skipped), value calculated using timer fr
equency.. 199.99 BogoMIPS (lpj=399996)
[    0.022754] pid_max: default: 32768 minimum: 301
[    0.027469] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.034007] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[    0.042158] ASID allocator initialised with 32768 entries
[    0.046519] rcu: Hierarchical SRCU implementation.
[    0.051520] EFI services will not be available.
[    0.055865] smp: Bringing up secondary CPUs ...
[    0.060553] Detected VIPT I-cache on CPU1
[    0.060588] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.060956] Detected VIPT I-cache on CPU2
[    0.060976] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.061310] Detected VIPT I-cache on CPU3
[    0.061329] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.061373] smp: Brought up 1 node, 4 CPUs
[    0.095671] SMP: Total of 4 processors activated.
[    0.100345] CPU features: detected: 32-bit EL0 Support
[    0.107488] CPU: All CPU(s) started at EL2
[    0.109525] alternatives: patching kernel code
[    0.114891] devtmpfs: initialized
[    0.120688] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma
x_idle_ns: 7645041785100000 ns
[    0.126913] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.140081] xor: measuring software checksum speed
[    0.177155]    8regs     :  2375.000 MB/sec
[    0.217182]    8regs_prefetch:  2052.000 MB/sec
[    0.257209]    32regs    :  2725.000 MB/sec
[    0.297240]    32regs_prefetch:  2309.000 MB/sec
[    0.297272] xor: using function: 32regs (2725.000 MB/sec)
[    0.301590] pinctrl core: initialized pinctrl subsystem
[    0.307799] NET: Registered protocol family 16
[    0.311498] audit: initializing netlink subsys (disabled)
[    0.316650] audit: type=2000 audit(0.264:1): state=initialized audit_enabled=
0 res=1
[    0.324273] cpuidle: using governor menu
[    0.328244] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval___
_))
[    0.335491] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.343177] DMA: preallocated 256 KiB pool for atomic allocations
[    0.365236] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.431058] raid6: int64x1  gen()   444 MB/s
[    0.499048] raid6: int64x1  xor()   453 MB/s
[    0.567123] raid6: int64x2  gen()   681 MB/s
[    0.635105] raid6: int64x2  xor()   600 MB/s
[    0.703158] raid6: int64x4  gen()   981 MB/s
[    0.771230] raid6: int64x4  xor()   737 MB/s
[    0.839275] raid6: int64x8  gen()  1164 MB/s
[    0.907300] raid6: int64x8  xor()   759 MB/s
[    0.975377] raid6: neonx1   gen()   735 MB/s
[    1.043386] raid6: neonx1   xor()   880 MB/s
[    1.111454] raid6: neonx2   gen()  1127 MB/s
[    1.179490] raid6: neonx2   xor()  1168 MB/s
[    1.247554] raid6: neonx4   gen()  1480 MB/s
[    1.315588] raid6: neonx4   xor()  1413 MB/s
[    1.383631] raid6: neonx8   gen()  1537 MB/s
[    1.451678] raid6: neonx8   xor()  1453 MB/s
[    1.451707] raid6: using algorithm neonx8 gen() 1537 MB/s
[    1.455672] raid6: .... xor() 1453 MB/s, rmw enabled
[    1.460603] raid6: using neon recovery algorithm
[    1.466071] SCSI subsystem initialized
[    1.469185] usbcore: registered new interface driver usbfs
[    1.474391] usbcore: registered new interface driver hub
[    1.479668] usbcore: registered new device driver usb
[    1.484741] media: Linux media interface: v0.10
[    1.489174] videodev: Linux video capture interface: v2.00
[    1.494630] pps_core: LinuxPPS API ver. 1 registered
[    1.499528] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
tti <giometti@linux.it>
[    1.508623] PTP clock support registered
[    1.512528] EDAC MC: Ver: 3.0.0
[    1.516221] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox drive
r.
[    1.523256] FPGA manager framework
[    1.526460] Advanced Linux Sound Architecture Driver Initialized.
[    1.532682] Bluetooth: Core ver 2.22
[    1.535890] NET: Registered protocol family 31
[    1.540272] Bluetooth: HCI device and connection manager initialized
[    1.546589] Bluetooth: HCI socket layer initialized
[    1.551431] Bluetooth: L2CAP socket layer initialized
[    1.556460] Bluetooth: SCO socket layer initialized
[    1.561865] clocksource: Switched to clocksource arch_sys_counter
[    1.567478] VFS: Disk quotas dquot_6.6.0
[    1.571286] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.583539] NET: Registered protocol family 2
[    1.584035] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192
bytes)
[    1.590054] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    1.597071] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[    1.603682] TCP: Hash tables configured (established 8192 bind 8192)
[    1.609956] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.615722] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.622133] NET: Registered protocol family 1
[    1.626609] RPC: Registered named UNIX socket transport module.
[    1.632237] RPC: Registered udp transport module.
[    1.636895] RPC: Registered tcp transport module.
[    1.641567] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.648387] Trying to unpack rootfs image as initramfs...
[    1.937277] Freeing initrd memory: 6472K
[    1.937818] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.943035] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters av
ailable
[    1.951599] Initialise system trusted keyrings
[    1.954893] workingset: timestamp_bits=62 max_order=18 bucket_order=0
[    1.962055] NFS: Registering the id_resolver key type
[    1.966206] Key type id_resolver registered
[    1.970346] Key type id_legacy registered
[    1.974331] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.981002] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    3.076071] NET: Registered protocol family 38
[    3.134537] Key type asymmetric registered
[    3.134567] Asymmetric key parser 'x509' registered
[    3.137902] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
47)
[    3.145198] io scheduler noop registered
[    3.149084] io scheduler deadline registered
[    3.153368] io scheduler cfq registered (default)
[    3.157995] io scheduler mq-deadline registered
[    3.162492] io scheduler kyber registered
[    3.202776] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.207266] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.215462] brd: module loaded
[    3.221034] loop: module loaded
[    3.222099] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.226787] libphy: Fixed MDIO Bus: probed
[    3.230606] tun: Universal TUN/TAP device driver, 1.6
[    3.234218] CAN device driver interface
[    3.239004] usbcore: registered new interface driver asix
[    3.243251] usbcore: registered new interface driver ax88179_178a
[    3.249278] usbcore: registered new interface driver cdc_ether
[    3.255072] usbcore: registered new interface driver net1080
[    3.260697] usbcore: registered new interface driver cdc_subset
[    3.266577] usbcore: registered new interface driver zaurus
[    3.272125] usbcore: registered new interface driver cdc_ncm
[    3.278486] usbcore: registered new interface driver uas
[    3.283027] usbcore: registered new interface driver usb-storage
[    3.289592] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc
0
[    3.296202] i2c /dev entries driver
[    3.301265] usbcore: registered new interface driver uvcvideo
[    3.305306] USB Video Class driver (1.1.1)
[    3.309851] Bluetooth: HCI UART driver ver 2.3
[    3.313788] Bluetooth: HCI UART protocol H4 registered
[    3.318886] Bluetooth: HCI UART protocol BCSP registered
[    3.324188] Bluetooth: HCI UART protocol LL registered
[    3.329265] Bluetooth: HCI UART protocol ATH3K registered
[    3.334647] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.340898] Bluetooth: HCI UART protocol Intel registered
[    3.346240] Bluetooth: HCI UART protocol QCA registered
[    3.351444] usbcore: registered new interface driver bcm203x
[    3.357061] usbcore: registered new interface driver bpa10x
[    3.362601] usbcore: registered new interface driver bfusb
[    3.368048] usbcore: registered new interface driver btusb
[    3.373468] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.379142] usbcore: registered new interface driver ath3k
[    3.384697] EDAC MC: ECC not enabled
[    3.388466] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac control
ler zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    3.401052] sdhci: Secure Digital Host Controller Interface driver
[    3.406338] sdhci: Copyright(c) Pierre Ossman
[    3.410662] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.416604] ledtrig-cpu: registered to indicate activity on CPUs
[    3.422303] zynqmp_firmware_probe Platform Management API v1.1
[    3.428052] zynqmp_firmware_probe Trustzone version v1.0
[    3.456797] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt,
ret = -22
[    3.459574] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    3.464713] zynqmp_aes zynqmp_aes: AES Successfully Registered
[    3.464713]
[    3.472334] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    3.478283] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    3.483925] usbcore: registered new interface driver usbhid
[    3.489166] usbhid: USB HID core driver
[    3.495420] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    3.499783] usbcore: registered new interface driver snd-usb-audio
[    3.506495] pktgen: Packet Generator for packet performance testing. Version:
2.75
[    3.513524] Initializing XFRM netlink socket
[    3.517371] NET: Registered protocol family 10
[    3.522171] Segment Routing with IPv6
[    3.525421] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.531619] NET: Registered protocol family 17
[    3.535625] NET: Registered protocol family 15
[    3.540046] bridge: filtering via arp/ip/ip6tables is no longer available by
default. Update your scripts to load br_netfilter if you need this.
[    3.552964] can: controller area network core (rev 20170425 abi 9)
[    3.559101] NET: Registered protocol family 29
[    3.563469] can: raw protocol (rev 20170425)
[    3.567705] can: broadcast manager protocol (rev 20170425 t)
[    3.573330] can: netlink gateway (rev 20170425) max_hops=1
[    3.579149] Bluetooth: RFCOMM TTY layer initialized
[    3.583630] Bluetooth: RFCOMM socket layer initialized
[    3.588738] Bluetooth: RFCOMM ver 1.11
[    3.592449] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.597720] Bluetooth: BNEP filters: protocol multicast
[    3.602913] Bluetooth: BNEP socket layer initialized
[    3.607842] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.613725] Bluetooth: HIDP socket layer initialized
[    3.618809] 9pnet: Installing 9P2000 support
[    3.622916] Key type dns_resolver registered
[    3.627629] registered taskstats version 1
[    3.631201] Loading compiled-in X.509 certificates
[    3.636334] Btrfs loaded, crc32c=crc32c-generic
[    3.648587] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 40, base_baud =
·249999) is a xÒ&ÉSÓSÓ&§WH¬Ëk׋«Ò+W/ª*LWY·X±¶ed
[    3.657538] console [ttyPS0] enabled
[    3.661128] bootconsole [cdns0] disabled
[    3.669522] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 41, base_baud =
6249999) is a xuartps
[    3.682308] of-fpga-region fpga-full: FPGA Region probed
[    3.688593] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[    3.695207] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[    3.702329] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[    3.709444] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[    3.716560] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[    3.723681] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[    3.730800] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[    3.737925] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[    3.745041] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[    3.752240] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[    3.759357] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[    3.766473] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[    3.773590] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[    3.780708] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[    3.787828] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[    3.794939] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[    3.802057] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[    3.809408] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_lo
cked:yes
[    3.821453] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0:
Xilinx DisplayPort Sound Codec probed
[    3.832182] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PC
M probed
[    3.840236] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PC
M probed
[    3.849196] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xi
linx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[    3.861715] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xi
[    3.874450] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xi
linx DisplayPort Sound Card probed
[    3.884656] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[    3.891675] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.898285] [drm] No driver support for vblank timestamp query.
[    3.904273] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8
008bbf5e0)
[    4.989883] [drm] Cannot find any crtc or sizes
[    4.994736] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display
on minor 0
[    5.002837] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsys
tem driver probed
[    5.012444] m25p80 spi0.0: unrecognized JEDEC id bytes: 00, 00, 00
[    5.019677] macb ff0e0000.ethernet: Not enabling partial store and forward
[    5.027123] libphy: MACB_mii_bus: probed
[    5.036860] macb ff0e0000.ethernet eth0: Could not attach to PHY
[    5.078740] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[    5.085289] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[    5.091780] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[    5.098264] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[    5.105022] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 32
[    5.141873] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA
64-bit
[    5.158270] rtc_zynqmp ffa60000.rtc: setting system clock to 2020-07-22 07:08
:13 UTC (1595401693)
[    5.167143] of_cfs_init
[    5.169604] of_cfs_init: OK
[    5.172532] cfg80211: Loading compiled-in X.509 certificates for regulatory d
atabase
[    5.255575] mmc0: error -110 whilst initialising SD card
[    5.317629] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.324163] clk: Not disabling unused clocks
[    5.328428] ALSA device list:
[    5.331389]   #0: DisplayPort monitor
[    5.335526] platform regulatory.0: Direct firmware load for regulatory.db fai
led with error -2
[    5.344132] cfg80211: failed to load regulatory.db
[    5.349493] Freeing unused kernel memory: 832K
[    5.377889] Run /init as init process
INIT: version 2.88 booting
Starting udev
[    5.512499] udevd[1772]: starting version 3.2.5
[    5.517393] random: udevd: uninitialized urandom read (16 bytes read)
[    5.523896] random: udevd: uninitialized urandom read (16 bytes read)
[    5.530396] random: udevd: uninitialized urandom read (16 bytes read)
[    5.541197] udevd[1773]: starting eudev-3.2.5
[    6.093916] [drm] Cannot find any crtc or sizes
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
INIT: Entering runlevel: 5
Configuring network interfaces... Cannot find device "eth0"
Starting Dropbear SSH server: Generating 2048 bit rsa key, this may take a while
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCRjXds72t8+pcCWhssBYAXt/OCFNqQXDG7EvoYWHiw
Q91mNczjJLgK8Hh8kIKznaNsCS2iblE0sbCQOeofyZojC6Fhblm9JkGAPbKay/b5IlspE1YYS8pHjOOM
FkucSnQjqWnamcjCCj0CIzpaI1+VD+EpWyxa4CsJcJyAXM9WyGhD6H3x9EGOO6o4wd2a4rCzovH2jbhW
GTxAkwV2YYhDIXRoipk7uD3C5zyfsJ096b5AQ+dg81u3B1EOjHjiGNIXjFo8lDACajh8pca/1Wta49TP
KO5uvHNdieOqv55Iy9j+14hr4tNpIs0bM9uRBBUWSsk9fM32fwO9dfIZg1YP root@hydra_linux
Fingerprint: sha1!! c9:a8:09:94:96:1a:17:8b:0a:71:25:1e:de:47:6b:7c:d4:1c:25:ca
dropbear.
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2019.1 hydra_linux /dev/ttyPS0
hydra_linux login: root
Password:
root@hydra_linux:~#
