kernel 3.12 driver for micro SD card
Hallo,
I am using the Xilinx OSL kernel 3.12 on a custom board with a micro SD card.
The system can boot from SD card, but in the Linux file system there is no device node /dev/mmcblk0
In the boot messages you can see these messages:
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
In the DTS I am using:
ps7_sd_0: ps7-sdio@e0100000 {
   clock-frequency = <50000000>;
   clock-names = "clk_xin", "clk_ahb";
   clocks = <&clkc 21>, <&clkc 32>;
   compatible = "xlnx,ps7-sdio-1.00.a", "generic-sdhci", "arasan,sdhci-8.9a";
   interrupt-parent = <&ps7_scugic_0>;
   interrupts = <0 24 4>;
   reg = <0xe0100000 0x1000>;
   xlnx,has-cd = <0x0>;
   xlnx,has-power = <0x0>;
   xlnx,has-wp = <0x0>;
What can I do to use the SD card in Linux ?
You may want to look at the 'broken-cd' and 'wp-inverted' DT properties and see if those help (https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/devicetree/bindings/mmc/mmc.txt ).
Also, this might be helpful: https://patchwork.kernel.org/patch/3706671/ , though, you need to see the card first.
I added to my DTS:
broken-cd;
wp-inverted;
now the SD card is usable.
Thanks a lot !
