libstdc++.so.6 on PetaLinux
Hey
I am trying to build my C++ application template using the Application Development Guide
When i try and build and run the user application "myapp" I get an error:
myapp: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
How can i install libraries for PETALINUX? does petalinux have an installer like apt-get or anything.?
I read on another thread that I could find the libraries on my Host and copy them to the emulator, but I am not sure which libraries from where and in what directory for the qemu.
Any help would be greatly appreciated.
Thanking You
Check this AR:
http://www.xilinx.com/support/answers/55976.htm
Hey
I copied the libstdc++.so.6 library from my host ubuntu and copied it to petalinux-v2013.04-final-full/software/user-apps/myapp
I then edited the makefile to copy this into my bin folder in the romfs directory as shown in "http://www.xilinx.com/support/answers/55975.htm" .
romfs: all $(DO_STRIP)
    $(ROMFSINST) -d $(APP) /bin/$(APP)
    $(ROMFSINST) libstdc++.so.6 /bin
The same error is seen:
root@Avnet-Digilent-ZedBoard-14_5:~# myapp
Am i copying the library into the right directory romfs/bin.?
Soumya Sheel
