Observer mishuk
modify existing rootfs files
Hello!
Currently I`m using Petalinux 2017.2.  I wonder what is a proper way to modify files already existing in rootfs?  For instance, those in /etc folder.  I tried adding custom application fstab-mount-sd, which replaces original /etc/fstab file, but after running:
      $>petalinux-build -c fstab-mount-sd
      $>petalinux-build -c rootfs
I get original /etc/fstab in rootfs.cpio
Please, help me!
Tags (3)
Re: modify existing rootfs files
Hi @mishuk
The approach of using a custom application just for modyfing an existing file within your rootfs is not a valid approach. As it's known, since 2016.4 release Petalinux is based on Yocto, so the way that the rootfs is populated is based on layers/recipes, so the best way to get information for this kind of questions is also looking for existing information related to Yocto.
I will base this answer on a existing post in the intel user forums, which can be used as a reference in this case.
As Petalinux project already has a user customization layer use (meta-user), create the folder structure for the recipe within it, rather than creating your own layer.
$ ls project-spec/meta-user/recipes-core/base-files/
base-files  base-files_%.bbappend
$ ls project-spec/meta-user/recipes-core/base-files/base-files
fstab
This way your own fstab will replace the one within your petalinux base-files recipe:
<petalinux_install_dir>/components/yocto/source/aarch64/layers/core/meta/recipes-core/base-files/base-files/fstab
Ibai
Ibai
Hi @mishuk
fstab
Ibai
Ibai
By the way, I will add that I changed the custom recipe in order to prevent bitbake warning messages related to the fact of using append or prepend for FILESEXTRAPATHS variable:
FILESEXTRAPATHS_append := "${THISDIR}/${PN}:"
Ibai
Observer mishuk
Thank a lot !  It works!  Some silly question: do I need to replace "%" in
project-spec/meta-user/recipes-core/base-files/base-files/base-files_%.bbappend
with exact version from
<petalinux_install_dir>/components/yocto/source/aarch64/layers/core/meta/recipes-core/base-files/base-files_3.0.14.bb
 I mean "3.0.14" ?
Tags (3)
Hi @mishuk
It's up to you. I mean, using the exact version makes your patch only be applied to certain version of base-files recipe (will work in this release). The % usage is  more generic and it's applied to any version of the recipe.
Ibai
I am trying to modify some similar files, located in /etc/ and trying to follow the solution here,
my recipes-core directory doesn't contain a folder called "base-files". Only an "images" folder, with "petalinux-image.bbappend"
I haven't drilled into Yocto much yet, so this might be a version issue; i'm using petalinux 2017.3, but what should be base-files?
