patch device tree to add /dev/uio0
i patch my device tree to enable /dev/uio by adding the following info:
uio0: uio@40000000 {
                        compatible = "generic-uio";
                        reg = <0x40000000 0x10000>;
here is my system.dts file:
http://ideone.com/0AsUFx
here is my zynq-7000.dtsi file:
http://ideone.com/MPWDrG
here is my uio.dtsi file:
http://ideone.com/ERRtCK
i would like to add an interrupt to /dev/uio0... you can add the following statement to support that:
interrupts = < 0 57 0 >;
interrupt-parent = <&gic>;
how can i select a non used interrupt?
what is gic?
